2013 windshield removal
Thank you,
Harry
Thank you,
Harry
Tools needed
J 24402-A Glass Sealant Cold Knife Remover.
J 39032 Stationary Glass Removal Tool.
Urethane Adhesive Kit or Equivalent
Isopropyl Alcohol or Equivalent
Cartridge-type Caulking Gun
Commercial-type Utility Knife
Razor Blade Scraper
Suction Cups
Plastic Paddle
The manual states to remove the following for windshield removal.
For the coupe, remove the roof lift-off panel.
For the convertible, lower the folding top.
Remove the hood air inlet screen seal
Remove the air inlet screen panel.
Remove the lower windshield supports (1) from the cowl panel, if equipped.
Remove the rearview mirror
Cover the following parts to protect from broken glass:
1. The upper dash pad
2. The defroster outlets and the A/C outlets
3. The seats and the carpeting
Remove the windshield weatherstrip.
Remove the windshield side reveal moldings
Remove the windshield side garnish moldings and retainer clips from the windshield frame
Remove the 4 rearmost screws that attach the top of the fender to the wheelhouse, the reposition the top of the fender for tool access.
Leave a base of urethane on the pinchweld flange.
The only suitable lubrication is clear water.
Use J 24402-A , J 39032 or equivalent in order to remove the window.
Remove the bottom of the window from the urethane adhesive using a long utility knife or similar tool. Keep the cutting edge of the utility knife against the glass. Do this from inside the vehicle.
Remove the windshield (1) from the vehicle with the aid of an assistant (2).
Those are the steps. I do alot of DIY on my vehicles, but this is one that I personally would never attempt. Getting the windshield out without breaking it is a 50/50 proposition at best.
I would have a professional do this, and they can likely fix your dash cover while they are at it. Most windshield places also do upholstery and such as well.
Good Luck
Good Luck with the repair to your dash pad. It's too bad that GM didn't offer a fix for these pads in the luxury dashes. The dash does look great in all leather.
