Dash info
Cruising
Dash info
so I just bought my first Corvette a few days ago and was wondering if anyone knows what it means on the 2007C6 on the right side of the steering wheel when you push the options button the display says options unavailable is there anyway to reset these options or what does that mean ?
Cruising
Options button on display panel
actually after further observation the key fobs are marked number one and number two so how does the key Bob work with the options button on the right side of steering wheel ?
The C6 can accept up to 4 fobs. Fobs number 1 and 2 can access the options. Fobs 3 and 4 can’t be used to access options. It doesn’t matter what number is printed on the fob. It’s the order they are programmed to the car. You can follow the fob programming procedure to reprogram the fobs or take them to the dealer to have them reprogrammed.
The number that your current fob that you got into the car with is programmed as may show a message on the DIC when you start the car. If it does and it's not "Driver #1" or "Driver #2", I'd go ahead and get both of them reprogrammed as fob #1 & fob #2. That reprogramming also deprograms any old fobs that may have been lost, stolen, or left behind.
