Lights
I think OEM's use around 4500K , which is the right answer if you want "white"
a google search claims 5000k is "white", either way, 6000k is definitely not white.
I was told (by people that know more than me) that HIDs are still a lot better than LED, but i'm sure that will start an argument here.
But more importantly, your car comes factory with HIDs, inside projectors, why do you want to mess with a good thing.
You could upgrade to bigger ballasts and bulbs (35W to 55W i think???) but then you'd have to worry about overheating your housings.
I was told that HID bulbs do get dimmer with age, so you could replace the bulb, maybe change the color to whatever you want.
Also I believe that OEM HIDs are expensive not only because they can, but also because they use better quality products [read better reliability], and personally i won't be changing the factory HIDs because i dont want to deal with the lower reliability of aftermarket.
I did change the DRLs/front turn signals to white LED with resistors, and changed the fog lights to some high power LED (just for looks if i'm being honest, not for visibility, if i wanted visibility i would have put HIDs in the fogs).
Any recommendations on "Switch back amber/white) driving lights? I want the DRL to be white and turn and parking to be amber.
i know there is some aftermarket seller that claims they have a harness that does exactly what you want I don’t know how they could do it, The only thing I can think of is using a micro controller . I don’t know the name of the company, but a 5 minute google search and you’ll find it.
I had a number of questions in the past and Cole is a stand up guy to deal with. I usually don't recommend Vendors unless I've really been treated well and felt they went out of their way when they didn't have to. Cole is one of those guys.
vette-lights.com
