TCC ? 4L60e/T 42 ECU P0741
Old 04-24-2019, 10:27 PM
solidaxel
solidaxel's Avatar
Default TCC ? 4L60e/T 42 ECU P0741
I keep getting a code Po741 but not all the time!
I can clear it BUT I have not located the problem so it will return.
The trans rebuilder says it is the computer/wiring, how can I prove it to the trans or computer (isolate the source) without removing the pan and checking the wiring
The harness is by Howell and they provided and tuned the computers, I have sent them back 3 times so I believe them to be OK
New LS 3 w/E38 and a 2003 4L60E w/T42
I have ID pin #7 at the trans and pin 25 at the computer
VOM test no ground w/key on, or no test light 12vdc to pin 25.
I have not tested pin 25 after the code P0741 !
It works, TCC, better when it is cold BUT not every time it is set for 54mph
Thanks for your help
Old 04-24-2019, 10:45 PM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
What model year Corvette are you talking about? That model year is frequently helpful in diagnosing problems.
Old 04-24-2019, 10:53 PM
solidaxel
solidaxel's Avatar
I thought I would start in this area first and ask questions!
The engine is a new LS3
To TCC ? 4L60e/T 42 ECU P0741
Quick Reply: TCC ? 4L60e/T 42 ECU P0741
