alignment specs
Old Apr 28, 2019 | 12:58 PM
jag1014's Avatar
jag1014
5th Gear
Default alignment specs
I have a 2013 c6 grand sport, would like to change to less aggressive alignment
Old Apr 28, 2019 | 01:06 PM
rkj427's Avatar
rkj427
Pro Mechanic
Attached are the Pfadt alignment specs.
Use the Street Performance for longest tire life.
File Type: pdf
Old Apr 28, 2019 | 01:44 PM
Eritosthenes's Avatar
Eritosthenes
I have a base C6, and for the past 11 years I have gotten excellent tire wear with a front camber setting of -0.10 degree. This is less aggressive than the factory spec of -0.45 degree which eats the inside corners of your front tires to the steel cord in 10K or less. All other stock settings are fine.
Old Apr 28, 2019 | 03:58 PM
FatsWaller's Avatar
FatsWaller
My understanding is that the GSs are more sensitive to alignment than the base models as far as tire wear is concerned. Here is a slightly more precise set of pfadt specs; insist that they set the alignment exactly. I used pure street.
File Type: pdf
Old Apr 28, 2019 | 04:21 PM
Oh Boy's Avatar
Oh Boy
No need to do anything. Just tell the tech to set the car dead center of GM specs, like this. Great tire wear and great handling. No guessing involved, just keep adjusting till the little needle is in the middle, pretty simple.
Old Apr 29, 2019 | 01:34 PM
GrandSportRob's Avatar
GrandSportRob
I did the pfadt street alignment last year on my 13GS when bought new tires.....
To alignment specs
