Ok so i brought car into shop and the hud was working i know the battery was weak but we put it on the charger for the day took it home that night and the hud was not working 2 days later still not working. I did unhook the battery for 10 seconds but still hud is not working. Any help would be great thanks.
The battery seems to be charging fine.
OK, next guess, Make sure the brightness is all the way up and move your head around and see if you can see any green light at all ..... maybe you had the infamous mirror fall.
Either way I think its time to pull the HUD. (I have an 05 and I replaced my HUD about 2 years ago, not that hard to do.)
Having a similar issue with my 06 HUD, It comes and goes, it returned on this mornings ride. I'm hoping it is due to the multiple times over the past year of me changing batteries.The HUD display is centered, and is bright as ever, nothing appears to be loose or out of place in the HUD projector. Good luck with your search and repair options, I'll check back here once I get my issue resolved and let you know what was done, Good Luck,
