Typical Problem?
Old May 29, 2019 | 08:54 AM
NEP2006's Avatar
NEP2006
2nd Gear
Default Typical Problem?
My 2006 won’t start but cranks very well. I’ve seen there have been numerous problems with fuel pump and fuel pump sensors woth the c6. It finally did start after cranking for an extended time. It later shut off while driving and is now at the dealer. Any thoughts?
Old May 29, 2019 | 08:58 AM
Katie22's Avatar
Katie22
Well we dont have any data on fuel pressure but the car is at least 10 years old and you can assume that a fuel pump could be a problem. If you had a fuel pressure reading you would know for sure..
Old May 29, 2019 | 12:35 PM
CJKC6's Avatar
CJKC6
Fuel pump relay - stopped my 05' dead
Old May 29, 2019 | 02:08 PM
NEP2006's Avatar
NEP2006
2nd Gear
Thanks much appreciated! Figured it was relay and or pump from what I had read in other posts. Was there any other problems after the relay was fixed?
Old May 29, 2019 | 03:14 PM
CJKC6's Avatar
CJKC6
Nope -- took care of the issue
To Typical Problem?
