Transmission Issue!!!
Old May 31, 2019 | 11:36 PM
Dylan James's Avatar
Dylan James
3rd Gear
Default Transmission Issue!!!
I have a 2008 base corvette with the 6l80e that i just changed the fluid in. When i drive it when its cold (90 degrees- 190 degrees) shifts through all the gears fine but undying hotter than 190 it won't shift into first. It through a p0751 code (solenoid A is off) and i can't find a new solenoid anywhere, or where it is located! Can someone please help me with the issue.
Old Jun 1, 2019 | 12:25 PM
Landru's Avatar
Landru
Having the code's 9/10ths of the problem, don't know location of solenoid, hoping others do.
BTTT for answers.
Old Jun 1, 2019 | 07:38 PM
HOXXOH's Avatar
HOXXOH
The first question to be asked is: Do you know and did you follow the correct procedure when changing and filling the fluid?
Next question: Did you change the filter?
Next: Did you replace the filter seal?
I have a gut feeling, but your answers might make me change my mind.
Old Jun 2, 2019 | 01:46 AM
Dylan James
3rd Gear
yes I followed the correct procedures changing the fluid, i changed the filter and took out the old seal and put the new one in and put on a new gasket.
Old Jun 2, 2019 | 11:15 PM
HOXXOH's Avatar
HOXXOH
The first thing to check with a P0751 code is the fluid level. So being very specific, relate the exact steps in the order you took for the fill procedure and where did you find the info of how to do it. I'm not trying to discredit your ability, but I need to assure that no step in the process was missed or incorrect that could have a bearing on the fluid level. The web is full of mis-information on the process
While you're at it, did the filter get fully inserted to the point it "popped" securely into place?
Old Jun 3, 2019 | 08:29 AM
wayback's Avatar
wayback
The A6 fluid/filter change is not just a drain n refill procedure like most are used to doing.
I let a certified Tech do mine as it's such a pain to do without a lift.
To Transmission Issue!!!
