Anyone found touch up paint or spray paint matching the jetstream blue? Before I get attacked . . . just want to paint some of the caps and plastic parts under the hood with spray. Wrap may melt or be really difficult for the circular caps. Thanks, cs
Try Automotive touch up. They do have jetstream Blue available in spray cans, touch up pens and touch up brush. https://www.automotivetouchup.com/to...2008/corvette/ The paint code is WA512Q, While the marketing name is Jet Stream Blue Metallic, the actual paint name is called Bluestream Metallic so don't be alarmed if that is what you see on the paint.
Also try your local auto parts stores in your area. I know that Napa in my area mixes spray cans any color code from GM. I have got Velocity yellow tint coat spray cans and the match is right on. It's good for underhood stuff for sure.
Good Luck
I used the Bluestream Metallic from Automotive touch up to paint my fuel rail covers. It's not an exact match. It seems a bit greener and darker. I believe Jet Stream Blue paint is a 3-stage paint process which makes if very difficult to match when they just mix all the different coats into one spray can. You may want to just order a small amount to test and see if you like it.
Thanks. I ordered a spray can and a paint pen. Though about just coloring the Corvette LS3 insert with a pen. I'll try one of the caps to check color. Thanks!
