What default message or mode do you let on the dic I used to let the remaining distance before refueling now I leave the coolant temp as default mode. What’s your
It all depends if I'm just around town, or doing a road trip.
I'll leave it blank most of the time, if I'm just at home.
On any road trip, I may keep an eye out for coolant temp, toggle the tire pressures now and then to assure there are no issues. I don't use runflat tires, so that is something I keep an eye on when on the road.
I rely on the alarms to keep me informed of any issues. I have Nav on the HUD, so that is usually what I'm paying attention to when on road trips.
Me personally I don't like any lights or messages on the dash, I like it clean. I don't even like driving in Competitive Driving Mode even thou it tightens up the steering nice and firm because it trips the active handling light to a steady on. Do you think you have to monitor your oil temp like something is going to go wrong?
I have the oil temp up, until it gets to operating temp, then I turn it off. its a subtle reminder to me not to romp on the gas til the oil is warm.
Another oil temp monitor here. With a dry sump motor it takes forever to get warm enough to stand on it. However, I almost always cycle through all the info screens just to be sure the voltage and tire pressure are good before I get too far from home.
Don't go getting all pouty on me, you walked right into that one and you know you did.
Wow your a mind reader also. So you know what I am thinking and having the proper gauge up for me to see would have stopped my lifter and cam from frying. Your one hell of a psychic.
Easy guys this is just friendly thread nothing scientific here
Maybe not but these motors don't like to be romped on until the oil temp is up. That is why I leave mine on the oil temp. Can see at a glance if I can get on it or not. Mine is an 07 and just puttering around my oil temps have a hard time getting to operating temp even after driving an hour or so.
It's not good for ANY motor.
I have a stock LS2, and it will get to around 190° in 8-10 miles, depending on the starting ambient temp.
