Airbags warning light
Normally it is the yellow connector under the drivers seat. Reseat the connector and zip tie together. Do a search and you’ll get more info with pics, I think there is a TSB or recall for it also, which pretty much is a zip tie.
And if you're reluctant to do this yourself, a dealer will do it for you, but it might not be cheap. A dealer did mine, but I honestly don't remember how much he charged.
Race Car Tech
The TSB should be free of charge since it is a safety system, but it isn't by GM. The dealer cuts the connectors and solders the wires together. Zip tie the connectors, and better option if you ever want to remove the seat from the car.
here is the TSB affecting all 05-13 C6 Corvettes
https://www.corvetteactioncenter.com...2017-1328.html
