center console removal
Old Jul 10, 2019 | 07:52 PM
marty1003's Avatar
marty1003
Default center console removal
Hey folks, I'm trying to remove the center console in my 05 coupe. I have removed the shift ****, two screws on the passenger side, removed the e-brake cover and side molding on passenger side. I watched a video that said I should have two star screws in my console box next to the cigarette charger...I dont have those. The console cover is not budging....what am I missing?
Old Jul 10, 2019 | 08:05 PM
madsonp's Avatar
madsonp
The two screws are next to the power port in the console, see this from the How To section of this forum. https://www.corvetteforum.com/how-to...igation-368176 If yours has the tomb stone shaped cover that has the airbag deactivation indication in it, you need to remove it first to gain access to the screws.
Old Jul 10, 2019 | 08:14 PM
marty1003's Avatar
marty1003
Mine has the selective ride switch. How do you get that cover off?
Old Jul 10, 2019 | 08:20 PM
madsonp's Avatar
madsonp
Originally Posted by marty1003
Mine has the selective ride switch. Thanks for the info...you rock!
Yep, forgot they put that switch there also, mine doesn't have selective ride so it has the airbag status indicator there instead. To remove the cover, just carefully pry up on the back of it (it's held on with a couple of clips), then when removing be careful not to break the tab off that's on the front of it.
Old Jul 11, 2019 | 01:18 AM
stavanger's Avatar
stavanger
Old Jul 11, 2019 | 11:55 PM
madsonp's Avatar
madsonp
So, how'd things turn out for you ? Did you get your console off ok ?
Old Jul 12, 2019 | 01:12 AM
owc6's Avatar
owc6
There are clips up by the radio as well.
Can you tell where it's sticking?
Old Jul 12, 2019 | 01:18 AM
madsonp's Avatar
madsonp
From his first post.
To center console removal
