Sounds like you may need an alignment while holding the wheel straight on. The other possibility is that someone had the wheel off and reinstalled it in slightly the wrong position. I have seen this issue several times and usually the alinement is the best fix.
Mine is doing the same thing! Shop said there is nothing can be done because of car's age. I don't fully believe that. But my wheels are aligned correctly.
There is ever so slight play in the rack bushings that could cause this, loosen and pry the rack in same direction as wheel is off ( I recall ) does not effect wheel alignment.
Complete Find another shop that actually knows what they are doing. Many (most) alignment "techs" just know to get everything in the green and call it good. It's really pretty easy to get it right: Center the steering wheel and set the toe, as explained in the ship manual. Just went through this at a Corvette specialty shop of all places. Keep looking.
What? Because of the cars age? What kind of an answer is that?
You can have a car that is correctly aligned but still have the steering wheel cocked if the steering wheel was not straight when the alignement was done. I have had it done using a level on the steering wheel while I was sitting in the car while the car was on the alignment machine to make sure the steering wheel remained perfectly level and did not move.
I'd get an alignment, but you can set the center point of the steering wheel by adjusting the tie rod ends and not effect the alignment.
I agree, I just changed all my outer tie rod ends and now my formerly straight steering wheel is slightly cocked to the right. I need an alignment too but my tires are needing replacement so I will put up with it until I get new tires.
The only thing I can figure is due to the car's advanced age, it might not survive the procedure as a result of the anesthesia.
When I sold GM and Chrysler products, we were told this was done to prevent the steering column from going through your
chest in a collision . It’s designed to veer right. This was before airbags and other built in safety devices.
Mine was that way, and I had an alignment with new tires that fixed the issue. It's cause by incorrect Toe in on one side, and toe-out on the other. There is A DIY on how to do it, but it's just as easy to F it up as well.
Actually you are affecting the alignment. Adjusting the tie rod ends changes the toe setting. However, typically when straightening the wheel by adjusting toe, the amount of change is small enough that it doesn't matter.
Get your car aligned and tell them make sure the steering wheel is centered!
Don't go to a dealer. And make sure the shop you select will do a precision alignment with PFADT specs- not the factory specs (too much slop). Call around to the alignment shops. Do NOT get a "lifetime alignment", they'll only use the factory sloppy specs.
And apparently not just any dealer. At Century Chevrolet near Denver, the Service Manager is supposedly a Corvette owner. And he does not recommend using other than the "straight ahead" factory alignment numbers. So I didn't go back.
I'll find another dealer. Also, someone discovered and said in another post here that with the adjusters (long nuts) on the Tie Rods, it is very nearly 1 degree of steering wheel angle per Flat on the nuts. That owner was successful in turning one of them Out, and the other one In, for his steering wheel centering. If you think that your current alignment is good, and turn the nuts with care, it may work fine.
