Navigation Issues
Old Jul 31, 2019 | 08:55 AM
hotroddougie's Avatar
hotroddougie
Default Navigation Issues
I had the same issue with the navigation as many of you have. I was finally able to 'fix' mine. First I used a can of compressed air to blow out any dust that I could in both slots. No discernible difference. While blowing out the slots, the felt shield blew back and I saw a stainless steel gate that blocks putting a disc in when there is already one in it. I took a small diameter piece of plastic and stuck in the slot for the Nav disc. When i swept it left to right, the blocker drops. I did this several times, and one time I could hear the motor trying to eject the disc, but it din not come out. I kept doing this until it tried to eject again, and immediately pushed the eject button. SUCCESS! Then I used a disc cleaner with the brushes. Now it is working like new. Hope this works for all you with the problem.
