Probably lost his clock ala battery disconnect. OP, go to the Tech and Performance forum and read thru the top sticky, will answer all your questions. Basically, you cant.
If that's the case, it may come back on its own, it may not.
If you're asking for how to set the clock and you can see a time set by the clock in the upper right corner of the display, say so and we'll tell you how to reset it.
Sorry, about that. Yes just purchased my 09 Vette. Everything works fine except the clock is not showing on screen...When I go to set clock it will not set?
