Programming Instructions for Sunset Orange
Step 7: Programming the Lear Car2U visor to the Exhaust
Commander unit.
1) Start the car. The valves in the mufflers should be closed.
2)To input the code into the Car2U Visor System, simultaneously
press all three Car2U System buttons for a few seconds and then
release to put the device into programming mode. It can be helpful to
use something to press all three buttons at same time. The Car2U
visor is sensitive so a straight edged item works well to press all 3 at
the same time. The indicator lights will blink slowly after the 3 buttons
are released. Within 2 minutes enter your supplied Exhaust
Commander code settings written on the bottom of the unit from into
your Car2U Visor by pressing and releasing the buttons
corresponding to the code you have. Your Code is on the bottom of
the unit. L = Left visor button and R = right viosor button.
3) After inputting the code, simultaneously press all 3 Car2U System
buttons and release. The indicator lights will turn on solid.
4) Press and hold the Car2U System button you would like to use to
control the exhaust. During the time you are holding the selected
button the indicator light will blink slowly. Immediately (within 1
second) release the button once you hear the Exhaust Butterflies
open. You will also hear the Relay click in the Exhaust Commander
receiver. Do not release the button until you hear the exhaust open.
You may need to hold the button for 1-20 seconds.
5) The single indicator light of your button will (begin to) blink rapidly
when programming is complete. If all three lights blink rapidly and the
receiver didnt activate and the relay didnt click, repeat Steps 2
through 5.
When the Exhaust Commander opens the butterflies there wont be a
delay in opening, but when closing them there is a 3 second delay as
the GM computer needs to boot up and then tell the exhaust
butterflies to close.
If you have any issues during your install please contact us right
away at 830-44-VETTE - Sunset Orange Creations
