Trans Fluid
Old Aug 11, 2019 | 10:50 AM
Rhettvette's Avatar
Rhettvette
Default Trans Fluid
Good Morning, Question: What is a good transmission fluid for the MANUAL TRANS? All the auto parts stores around hear scratch their *** when you
tell them Manual trans fluid. Everything seems to says Automatic. GM 10-4033 is order only here. Trying to get this Vette off the hoist.
Old Aug 11, 2019 | 11:25 AM
ssg10587's Avatar
ssg10587
You can find it cheaper elsewhere but this is what you should use:
Amazon Amazon
Old Aug 11, 2019 | 12:01 PM
Rhettvette's Avatar
Rhettvette
Default Gm
Thank you for your reply. The GM is a week away. I ordered but I would like to finish this GS on the lift. Looking fo a substitute brand I can get asap
Old Aug 11, 2019 | 12:30 PM
Garry in AZ's Avatar
Garry in AZ
I have used Redline MT-90 and Royal Purple Syncromax transmission fluids in several C5's and C6's with no problems. I actually prefer the Redline oil to the GM oil.
Old Aug 11, 2019 | 01:07 PM
Spaceme1117's Avatar
Spaceme1117
If I remember correctly the manual trans uses Dexron III automatic trans fluid. Should be able to find this at any auto parts.
Old Aug 11, 2019 | 04:41 PM
Rhettvette's Avatar
Rhettvette
Hey Garry in Az. Those are great fluids. The only problem is nobody stocks it around here. I have to order and that takes 5 to 6 days.
All the good old speed shops are gone and the counter people here are from a younger generation. I think one day
soon the manual trans will be history.
Old Aug 11, 2019 | 04:49 PM
Rhettvette's Avatar
Rhettvette
You maybe correct however owners manual says GM 10-4033 manual trans fluid. Transmissions are a bit** to replace.
Thank you for your reply however.
Old Aug 11, 2019 | 07:56 PM
steig's Avatar
steig
Amsoil Synthetic Fluid is what I use.
Old Aug 12, 2019 | 01:03 AM
nhoffman1987's Avatar
nhoffman1987
I used Amsoil Torque Drive and was very pleased.
Old Aug 12, 2019 | 01:11 AM
BackInBlack05's Avatar
BackInBlack05
Redline D4ATF.
Old Aug 12, 2019 | 01:14 AM
boonie c4's Avatar
boonie c4
Red line!
Old Aug 12, 2019 | 02:08 AM
theandrewo's Avatar
theandrewo
Just pumped my mn6 full of Amsoil Synthetic torque drive today
Old Dec 26, 2019 | 07:49 PM
wydopnthrtl's Avatar
wydopnthrtl
OP said he wasn't going to use Amsoil. But I've used it on a T56 in the past and after 200 miles or so it got better and better. After 1000 miles it was shifting MUCH smoother. I plan to do the same with my Z06 next summer
Old Dec 26, 2019 | 11:17 PM
BackInBlack05
https://www.redlineoil.com/d4-atf
A lot of manual trans use ATF nowadays.
To Trans Fluid
