2005 will not start
Old Aug 26, 2019 | 04:44 PM
mitsuvette's Avatar
mitsuvette
Default 2005 will not start
Hi I have this 2005 c6 that when I hit the start button I get a loud click and nothing. This just started happening and I'm not sure if it's something electronic or a bad starter.
but everything appears to shut down for a few seconds then all appears normal until I try to start the car again and same thing all over again.
Old Aug 26, 2019 | 04:45 PM
gayvettelover's Avatar
gayvettelover
either dead battery and or alternator and or starter
Old Aug 26, 2019 | 05:47 PM
saplumr's Avatar
saplumr
Does the DIC say no FOB detected?
Old Aug 26, 2019 | 08:02 PM
agorena123's Avatar
agorena123
I had same issues and symptoms. Replaced battery and battery cable connectors as previous owners had changed OEM connectors and they were too small. Battery was ok but tested a little weak and mechanic thought it would fail soon. Everything was fine for a week or so then issue popped up again, on inconsistent basis. Replaced starter and no issues since.
Old Aug 27, 2019 | 09:50 AM
CJKC6's Avatar
CJKC6
Is this a manual or auto? If manual, I am thinking the reverse lock out switch
Old Aug 27, 2019 | 11:29 AM
Landru's Avatar
Landru
Are there any codes?
Readers are inexpensive and most auto parts stores will check codes for free.
Old Aug 27, 2019 | 06:50 PM
mitsuvette's Avatar
mitsuvette
Thanks, I'll look at those.
Old Aug 27, 2019 | 06:51 PM
mitsuvette's Avatar
mitsuvette
No and I replaced the FOB battery just to be sure.
Old Aug 27, 2019 | 06:53 PM
mitsuvette's Avatar
mitsuvette
I'm checking out the starter as well as the battery and alternator
Old Aug 27, 2019 | 06:54 PM
mitsuvette's Avatar
mitsuvette
No codes, I have a reader and it checked out ok.
Old Sep 5, 2019 | 11:45 AM
JasonAndrew's Avatar
JasonAndrew
Clicking and no starting is a classic symptom of a battery that doesn't have the Amps to start the engine.
Old Sep 5, 2019 | 03:43 PM
NBVette_Canada's Avatar
NBVette_Canada
Just had the same issue with my 2007. Pushing start button would give single click and show check engine light but nothing else. Releasing clutch would give normal light show. Turned out to be starter and a bad/weak battery. replaced both and working ok since.
Old Sep 9, 2019 | 01:16 PM
Ratical 08's Avatar
Ratical 08
I have this exact same symptom with my 2008 A6 car. Very random though. Car can sit over a week and starts right up. Gauge shows charging normally. shut it off at a gas station or something and it will do it. Sounds and acts almost like a bad ground or poor connection on mine. When I hear the loud click it seems like the car loses power. I hit it again sometimes once, sometimes takes 3 or 4 times and it starts. I have to go through it and check all battery connections and grounds.
Old Sep 9, 2019 | 01:21 PM
Mr. Jean's Avatar
Mr. Jean
Did you have the battery load tested? It's free and you can go from there.
Old Sep 9, 2019 | 04:17 PM
Ratical 08's Avatar
Ratical 08
I will test the battery and pop the starter out to have my buddy go through it. I know what a normal car sounds like when the battery is low or the starter is bad, this doesn't sound like either but I have never had a push button start car either so I am not ruling that out. It actually sounds more like an electrical "snap/pop" like what you get if the battery post is corroded or loose. I will check those and clean them as well when I check the load. I wasn't sure if there was some inherent quirk these cars have like the shifter cable issue. Thank you for all the replies and suggestions. Hopefully the OP and I both get these cars figured out!
Old Sep 9, 2019 | 04:26 PM
carsnpars's Avatar
carsnpars
This happens about once a year for me. I’ll go out and when I sit in the car, it doesn’t make those little sounds....then won’t turn over. I take off the pos cable for ten minutes and put it back on and it starts.
Old Sep 11, 2019 | 03:59 PM
Emfuser's Avatar
Emfuser
It's an 05, which means there's a good possibility this is a column lock problem. Only the C5s and the 2005 C6s have this problem. Even a dealership will miss that one. I know mine did.
OP, get this product to bypass the column lock:
https://www.tickperformance.com/tick...5-corvette-c6/
Make ABSOLUTELY SURE you follow the part of the directions where you make sure your column lock is disengaged before you install the bypass.
Old Sep 12, 2019 | 09:24 AM
Jstan2014's Avatar
Jstan2014
Op, did you have any luck with your starting issue?
To 2005 will not start
