ECM question..?
Old Aug 29, 2019 | 09:49 PM
marcus pugh's Avatar
marcus pugh
3rd Gear
Default ECM question..?
I have a 2008 C6,currently at the shop. Vehicle seems to start off in 3 gear. Drive in auto trans car will shift correctly. Put car in manual paddle shift display just scrolls will not go into first gear.
No codes showing per mechanic and not a transmission concern.
Anyone experience this problem and please any suggestions.
Marcus
Old Aug 30, 2019 | 06:51 AM
4SUMERZ's Avatar
4SUMERZ
I have a 2006 A6 and with over 1000,000 miles, I have not experienced this thus far.
Get the mechanic to check all the electrical connections at the transmission for bent pins, or dirty contacts. Get him to clean them up, put some dielectric grease and reconnect. Hopefully that is your issue.
Good Luck
Old Aug 30, 2019 | 08:39 AM
marcus pugh
3rd Gear
Thank you 4Sumerz I will pass that info along and get back to you
Old Aug 30, 2019 | 09:08 AM
steig's Avatar
steig
Good Luck
Good info! Corvette people helping corvette people.
Old Oct 5, 2019 | 11:56 AM
marcus pugh
3rd Gear
Default Ecm
Well it took about a month to learn that it was the Transmission Control Module which is housed in the transmission. Now the part has been ordered from GM but guess what They Are On Strike!!!!
Oh well patience the virtue..could ha e been worst issue.
Thanks a lot
Old Oct 5, 2019 | 12:04 PM
4SUMERZ's Avatar
4SUMERZ
Thanks for getting back on this thread. It may help someone else with similar symptoms.
Good luck with the repair
To ECM question..?
