Convertable Top
Old Sep 6, 2019 | 01:16 PM
Richiez's Avatar
Richiez
Default Convertable Top
I have a 2011 C Grand Sport Corvette with 40k miles. Today I attempted to put the roof down and nothing happened whan I hit the down button?
Any suggestions?
Old Sep 6, 2019 | 01:20 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Did you check to make sure the top "guard" in the trunk is firmly in place?
Old Sep 6, 2019 | 01:48 PM
Bob Paris's Avatar
Bob Paris
Any suggestions?
In addition to making sure the partition is in place, verify that your windows index. If they don't, then the top will not work until you re-index them.
Old Sep 6, 2019 | 02:32 PM
Richiez's Avatar
Richiez
Thanks for your suggestion.
Yes it is vclosed. In the past if it was open I would get a message on the DIC.
Now nothing?
Old Sep 6, 2019 | 02:33 PM
Richiez's Avatar
Richiez
Whats a window index?
I get no message on the DIC,
Old Sep 6, 2019 | 02:34 PM
Richiez's Avatar
Richiez
Could it be a fuse?
Old Sep 6, 2019 | 05:19 PM
C4Lou's Avatar
C4Lou
Check the owners manual for how to index the windows. Indexing is where the windows move down slightly when opening the door, then back up when closing to ensure a tight seal.
From memory, turn the ignition on (run mode), lower the window, then raise it, holding the switch for several seconds after the window is all the way up. May have to do it for the passenger window too.
If that doesn't help, see if the top will raise and lower in accessory mode (not run). That's helped me in the past when my top wouldn't operate. Don't forget, if you have a manual (like me), the E-Brake has to be engaged.
Hope this helps!
Old Sep 6, 2019 | 05:31 PM
Richard F's Avatar
Richard F
My bet is on the part in the trunk is loose from its connections.
Old Sep 6, 2019 | 05:33 PM
USA1 427's Avatar
USA1 427
Is the trunk shut? Does your vert have a panel in the trunk that snaps up, and it has to be snapped or the vert won't work.
Old Sep 6, 2019 | 06:48 PM
Richiez's Avatar
Richiez
Thanks, its working now.
But I don’t know what I did to fix it.
I tried putting the windows up, that didn’t work.
I tried it in accessory mode that didn’t work
Tried again after starting the car and the DIC said the trunk lid was ajar (first time I got that message) , It wasn’t so I opened it and closed it. The DIC then said the trunk cover wasn’t closed.(first time I got that message) I opened the trunk and it was not closed, but I checked it earlier and it was closed.
I closed, the cover, closed the trunk put the windows up and started the car.
Opened the roof latch, at this time the windows automatically went down. I pushed the roof down button and it worked??
Thanks for your help.
Old Sep 7, 2019 | 08:15 AM
USA1 427's Avatar
USA1 427
There's a sensor on the right side of the cover in the trunk and if the cover isn't snapped right, that top won't move. We've probably all had that happen. Glad you figured it out.
Old Sep 7, 2019 | 11:44 PM
owc6's Avatar
owc6
My money is on this.
If the windows aren't indexed, there will be no msg.
In order to index windows. put both down, pull them both up all the way, put them both down pull them both up all the way. (according to the OM)
Although, I find that just putting them up and holding for three seconds to be sufficient.
Old Sep 8, 2019 | 09:16 AM
Red12's Avatar
Red12
After you try all of the above, it could be what happened to me. My top would open and close intermittently until one night I got soaked in the pouring rain. The top would not close. Time to bring it in to my local dealer. They determined that some electrical module was the culprit. They would over night the part from some where and would not be covered under warranty because the car was 4 months past. The mechanic told me that when the car was assembled, too much grease was used and dripped on the module and shorted it. The dealer had the car for 5 days and cost me $1100. I wrote to GM customer service and they denied my claim. The car has been ok since. Good luck.
Old Sep 8, 2019 | 12:00 PM
449er's Avatar
449er
CF Community Team
Make sure the trunk is shut
To Convertable Top
