Headlight lens coating
Old Sep 12, 2019 | 11:37 AM
csnow's Avatar
csnow
My headlights had clear sprayed on them which is yellowing and cracking. What grit should I start with to remove the flaky clear coat?
Old Sep 12, 2019 | 11:39 AM
Narddog's Avatar
Narddog
600 then work to a lower grit until it starts coming off. I needed 180 to get mine off.
Old Sep 12, 2019 | 05:35 PM
info@umnitza.com's Avatar
info@umnitza.com
Supporting Vendor
Originally Posted by candipogo
Do any of you guys recommend a headlight lens coating?. Recently bought a 2007 coupe. The headlight lens have been polished. And, I believe the coating has been polished off. There must be 50 different ones available. Some say must use heat lamp to cure.others do not. Anybody have experience with one of these coatings.
Originally Posted by maverickmk
Interesting, I need to restore my headlights. I'll be watching this for some of the advice.
Sorry that I'm no help.
I would like to find something that's more or less permanent like the factory stuff. Nobody in my area offers or installs a semi permanent coating. I have seen a few sprays and a couple you wipe on. Since I'll have to do it myself, I am hoping to stay away from one that requires a special lamp or heat to cure.
Thanks, phil
For those of you that have "crazing" haze+cracking, it's internal and won't be restored.
Better to just get new lenses - coincidentally we sell the DOT units
Old Sep 12, 2019 | 05:38 PM
csnow's Avatar
csnow
Were you able to restore them with the headlights installed or did you pull them?
Old Sep 12, 2019 | 05:55 PM
Narddog's Avatar
Narddog
Did mine installed. Just taped around the paint and went to town with a drill and sanding pads.
Old Sep 12, 2019 | 07:20 PM
jimijam's Avatar
jimijam
Your post can be taken either way.
Um, nope. Perhaps there is a language barrier here? Maybe you can plug my post into the Google Translator. Good luck.
Old Sep 12, 2019 | 07:24 PM
jimijam's Avatar
jimijam
Originally Posted by LilNutSac
No need to thank me:
Deez!
As requested.
Thank you for posting the same link I posted in #11 above. Congrats on being late to the game. Carry on.
Old Sep 12, 2019 | 08:00 PM
Narddog's Avatar
Narddog
Your ignorance is showing dude. Since I took pics of my entire process let me show you what 1k looks like on the OEM lens.
Compare that to when I wetsanded with 3k
So if you wanna stop at 800, go for it. Your lights will have a ton of scratches..
Old Sep 12, 2019 | 08:20 PM
jimijam's Avatar
jimijam
Clearly, English is not your first language. Either that, or you have zero comprehension skills. Good luck to ya anyway, kid.
Old Sep 12, 2019 | 08:38 PM
Narddog's Avatar
Narddog
Lmao whatever dude 🤣😂😂
