Help ID my midpipe?
Old Sep 19, 2019 | 10:20 AM
Narddog's Avatar
Narddog
Default Help ID my midpipe?
Can someone help ID what this is? I was under the impression this whole time it's stock but I cannot find any OEM pictures of midpipes that match. Tried to get the best pictures but it's hard with barely any room!
Old Sep 19, 2019 | 12:22 PM
LMB-Z's Avatar
LMB-Z
I guess I don't understand. Does the car have headers or axle back exhaust? I seriosly doubt someone would replace the midpipe without doing headers or axle back or both. Just curious, why are you worried about whether the midpipe is stock or not?
Old Sep 19, 2019 | 12:34 PM
Narddog's Avatar
Narddog
Stock headers and Corsa sport mufflers. I thought the midpipe had an H pipe and if it was an X it looked like the below. This almost looks aftermarket. Maybe it was another version of the stock midpipe I wasn't aware of either.
almost looks like someone just took the h pipe and had an X welded in but who knows.
Old Sep 19, 2019 | 01:07 PM
saplumr's Avatar
saplumr
Looks like a X-pipe to me. If it doesn’t have a short section between the two making an H it’s an x
Old Sep 19, 2019 | 01:09 PM
Narddog's Avatar
Narddog
Looks aftermarket though yeah?
Old Sep 19, 2019 | 11:01 PM
buckmeister2's Avatar
buckmeister2
Attached are what base X-pipes should look like. Neither of my C6's ('08 and '12) have discoloration like yours does. which makes me think yours might have been added for some reason. Or, possibly, high heat and lots of moisture caused yours to discolor, nothing to really worry about, unless you want precisely stock parts.
The pipes on the left are from an '08. The ones are the right are from the '12
The '08 are spread 1 1/4" wider at the exit, and flared out more. The '12 pipes have two non-metered cats. Both are perfectly stock.
To Help ID my midpipe?
