Winter Storage
Old Oct 8, 2019 | 10:43 AM
  #41
sonnysucks's Avatar
sonnysucks
Originally Posted by BWF07
I always feel sorry for all of you that have to go through this every year. Seeing I live in Florida I cannot help much, but I am sure you will hear from many that do have to go the winter storage route. What I have always wondered, is why so many select a date and that is when they put the cars away. It would seem to me until the first snow falls or the first really cold snap I would keep it out on the road.
Don't feel bad for us! I get to rip in 80-90 degrees and a day later get to experience 50-60's air temps and road temps. I do drive mine until it gets ugly out, but getting stuck in snow isn't an inconvenience, it literally cannot happen.... the roads get way ******* sooner than that, just road grime from falling leaves and rain is enough to coat the road in debris and whatnot that give traction issues with cars with power even days when it's dry and warm... I try to get through October and into November and then have a good resting period through March to get maintenance done and wax my car about 50 times over the downtime. I also commute about 7 miles so I can get home if the weather comes in during these months.
To answer the question, I am going to run PUMP gas instead of Ethanol, will get at least a tank or so through it and then will fill up with some proper fuel stabilizer like BG products or the like?
My last question is if I should jack stand it all season or if I should lift it up and down during the off season? I am on Nitto NT05Rs and don't want to kill those sitting, so I'd likely jack it up here and there and roll them over...?
Old Oct 8, 2019 | 11:30 AM
  #42
Iceaxe's Avatar
Iceaxe
Originally Posted by skar
Not sure if this is true but my tuner said fuel stabilizer will rob octane also.
Actually the opposite is true. Gasoline is a complex formula and when gasoline sits the molecular bonds begin to break down and the fuel goes through what is known a phase separation, which can lower the octane rating up to three points. Stabilizer slows this process.
Also the fuel stabilizer is not just for the fuel in your fuel tank, but the fuel in the entire system. If used properly it protects the entire system, including fuel lines and injectors, which have a habit of getting gummed up sitting with old fuel. Something else to consider is the smaller the fuel volume the quicker it breaks down.
YMMV
Old Oct 8, 2019 | 08:50 PM
  #43
Josh M's Avatar
Josh M
St. Jude Donor '19,'21-'22-'23-'24
Ended up getting the Race Ramp Flatstoppers. I ended up getting ones that were 16" wide that said could handle 14" tires. I wasn't sure if having a little hanging off the edge would really matter, I'm guessing not but if I'm gonna spend the money might as well spend 20 bucks more to get ones that fit the whole tire!
Old Oct 8, 2019 | 09:05 PM
  #44
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
^ Or you could have paid someone to kick you in the nuts for $20 and save $250+.
Old Oct 9, 2019 | 11:34 AM
  #45
oldcanuck's Avatar
oldcanuck
I tried to tell him just put in 40# of free air and leave in alone until spring.
Oh well.
Must be nice to be wealthy.
Old Oct 9, 2019 | 06:46 PM
  #46
Josh M's Avatar
Josh M
I think I could have found someone to do that for 10 or less!
