Manual Transmission problems
Old Sep 30, 2019 | 02:48 AM
Jrd27's Avatar
Jrd27
8th Gear
Default Manual Transmission problems
Hello, I just made a trade for a 2005 c6 “Lingenfelter” ls2 manual transmission about 6 hours ago and my first gear just went out out of the blues and it was working great at first then started grinding a bit, then in 2nd it makes a wired clunky noise at times when accelerating and now each gear started somewhat acting up right after all of this. like it was rough to put in gear and then the problem would go away for a moment and come back, except for 1st gear that it just wont go in at all mind you this just happened from one second to the other. The clutch is hanging mid way, so I assume that’s bad as well. Now the sad part is I just traded for the car and at first it was driving extremely good 3 hours into my drive home before all of this started to happen. My question is, will I have to rebuild the tranny? Or synchros? Or is there something else causing it. I’d like to keep the car since it’s worth keeping but trying to figure out what exactly is up with it before I go calling shops.
Old Sep 30, 2019 | 05:42 AM
enventr's Avatar
enventr
If you traded it in at a dealer, didn’t they have a 30 day warranty ?
Old Sep 30, 2019 | 05:43 AM
Jrd27's Avatar
Jrd27
8th Gear
I wish, it was a private seller.
Old Sep 30, 2019 | 05:47 AM
Jrd27's Avatar
Jrd27
8th Gear
And don’t get me wrong if it something crazy I’ll get my trade back but Maybe there’s a helpful source here and I can get an idea of what it may be because it can be several things or the tranny is just jacked but before taking action I’m looking for a solution because I’d like to keep it.
Old Sep 30, 2019 | 09:14 AM
Landru's Avatar
Landru
How many miles car have?
Syncros is my first guess, isn't unheard of 1 or more go bad.
2nd guess bad master, lousy design using cheap materials to start with and also cheapest to remedy.
Tranny has to be dropped, opened & inspected so cause can then be determined & fix implemented.
Unfortunately sure sounds like seller pulled a fast one, passing a hot potato he knew of to you. Stinks.
Ligenfelter's a very good upgrade &, expensive akin to a Calloway, IMO repair worth the $.
Old Sep 30, 2019 | 09:19 AM
Muhstang81's Avatar
Muhstang81
Is the pedal dropping or slightly dropping? Look into failing master cylinder before assuming it's the tranny, that can cause grinding, hard to go into gear etc...Also mine is after market and would slowly drop after driving for awhile, checked all the lines and was able to tighten up master to slave just a smudge and that helped significantly.
Old Sep 30, 2019 | 09:44 AM
Dutch08's Avatar
Dutch08
Yep, check out the master. But it sounds like its something in the drive line. If you do your own work its going to add about $1000 to car for clutch and hydraulics for example just in parts. If you are going to have it done maybe $1000+ on top of that. A dealer would be more than a competent independent but you get the idea.
I guess its going to depend on what you originally paid for the car, if you want to keep it, and if you could do it yourself.
Old Sep 30, 2019 | 06:03 PM
torquetube's Avatar
torquetube
You've buried the lede. A failing clutch would cause all your gear engagement problems. Troubleshoot the clutch first.
Old Sep 30, 2019 | 10:29 PM
csnow's Avatar
csnow
You probably just need a clutch and new master/slave. If you do happen to need a transmission, I am pulling mine out in short order (Z51) and replacing it with a Z06 trans/diff. PM me if you are interested.
Old Oct 1, 2019 | 05:12 PM
Jrd27's Avatar
Jrd27
8th Gear
Found the issue, bad slave cylinder and clutch
Old Oct 1, 2019 | 05:13 PM
Jrd27's Avatar
Jrd27
8th Gear
That’s exactly the issue! That and the slave
Old Oct 1, 2019 | 05:15 PM
Jrd27's Avatar
Jrd27
8th Gear
I can work on it but this is a job I’m not to comfy with luckily I remembered a buddy of mine has a shop and works on all of this cars so I got a decent price for labor.
Old Oct 1, 2019 | 05:17 PM
Jrd27's Avatar
Jrd27
8th Gear
Default Thanks for the help guys!
Turned out to be a bad clutch and slave cylinder. I appreciate the help!
Old Oct 1, 2019 | 06:00 PM
Dutch08's Avatar
Dutch08
Suggestion ....upgrade to an LS7 clutch it is a direct bolt in and made a huge difference in my '05
Old Oct 1, 2019 | 11:58 PM
Jrd27's Avatar
Jrd27
8th Gear
That is exactly what I ordered, thanks for the heads up!
Old Oct 2, 2019 | 11:07 AM
Landru's Avatar
Landru
Good to know WTH's happening. Better yet a deal on labor.
Since rear has to be dropped anyway, consider the upgraded collars (?) for synchs also.
Supposedly newe design/material used for these components insures longer synch life.
No C6 owner wants to go through the rear end crap twice, what can be done (upgraded) is done once is important.
To Manual Transmission problems
