Winter Storage Question
Old Oct 25, 2019 | 08:58 AM
Vette_Fever's Avatar
Vette_Fever
4th Gear
Default Winter Storage Question
When storing your Corvette in the garage, under a car cover, in snow country do you do anything special to protect the rear of the car that is exposed to snow when the garage door is up? I am stumped as to a satisfactory solution.
Old Oct 25, 2019 | 09:08 AM
Loon's Avatar
Loon
If you are that worried sounds like you need a Car Capsule.
Old Oct 25, 2019 | 09:14 AM
cmonkey713's Avatar
cmonkey713
What many do is put the car on jack stands prevent tire flat spotting. Don't forget to get a good quality battery tender to keep the battery charged. Next wax or seal the paint to protect the finish from anything that may come in contact. Check the anti-freeze, add staybill to the gas tanks and use a soft underside all weather car cover. If the garage door is left open you could always put a blue tarp over the rear half of the car for additional protection. Some have issues with rodents that you may also want to address if it is a problem in your area. Some members have an annual regiment for winter storage which they may want to share here.
Old Oct 25, 2019 | 09:34 AM
messman750's Avatar
messman750
I purchased a car bag. Drive it on the mat and zip it up for the winter and forget about it!
Old Oct 25, 2019 | 09:55 AM
449er's Avatar
449er
CF Community Team
An outdoor all weather car cover should protect the entire car when the garage door is open
Old Oct 25, 2019 | 09:57 AM
saplumr's Avatar
saplumr
It’s never a good idea to leave a vehicle on jack stands which unloads the suspension.
Old Oct 25, 2019 | 10:44 AM
FatsWaller's Avatar
FatsWaller
So, I live in snow country and the vette sleeps in the garage covered with a car cover that covers the entire car - no paint can be seen. I don't leave the garage door open either. The only time that I go in there is to get ice melter, and that only takes a minute. If you are worried about snow blowing in there, I'd be more worried about raising the humidity inside your garage when the snow melts. If your car cover doesn't cover all of the car, I suggest that you get one that does. I can't see how getting some small amount of snow on the car cover could hurt anything. You can just brush it off and sweep it out of the garage. Or am I missing something obvious here?
Old Oct 25, 2019 | 11:05 AM
4SUMERZ's Avatar
4SUMERZ
Here is a pic of where my car sits in the garage, during the snowy months. I only open the main door to take my snowblower out, but snow never penetrates that deep into the garage.
My storage method for the past 10 years are:
1) Put stabil in for the last fill up before hibernation
2) Pump up the tire pressure to 40 psi, and check once in awhile
3) Clean the interior, then place bounce dryer sheets in the car to keep it smelling fresh
4) Hook it up to a battery tender (Battery Tender Plus in my case)
5) Leave the hood open some so it it not latched
6) Put the car cover on
7) Leave till Spring.
Depending upon the mileage on the oil, I may change before hibernation, or after a few thousand miles in the Spring.
Old Oct 25, 2019 | 12:23 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
It will be fine, it;s a Chevy.
Old Oct 25, 2019 | 01:21 PM
SlothX311's Avatar
SlothX311
I do this for winter storage. I take the wheels off though, good opportunity to deep clean them.
Old Oct 25, 2019 | 06:33 PM
cmonkey713's Avatar
cmonkey713
That is exactly what you want to do. If not the tires can flat spot unless they are removed and the composite springs are at rest. This is why you never see professional race cars sitting on the ground for any length of time
Old Oct 25, 2019 | 07:17 PM
Red Devil's Avatar
Red Devil
Tires getting road spots are almost a thing of the past. What i do is park on 1" blue rigid insulation and iveI never had an issue and I have factory original tires from 2012 😀
Old Oct 25, 2019 | 08:06 PM
Aggie76's Avatar
Aggie76
I back mine into my pole barn and it's resting on pieces of horse stall mat, 1" rubber that are on a tarp. And I do the same as 4SUMERZ with prep, using a CTEK,
with the addition of 000 steel wool in tailpipes.
Old Oct 25, 2019 | 08:10 PM
Trebor's Avatar
Trebor
I just shut my garage door when it snows.
Old Oct 25, 2019 | 08:44 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
I agree. Do NOT let it hang.
Old Oct 25, 2019 | 09:21 PM
C6 Snowboarder's Avatar
C6 Snowboarder
I use a goose down comforter laid over the rear of my C6 if I ever have to open the garage door in the snow., Also have 2 window fans - one on each side blowing the snow away. That stuff can be quite caustic to Corvettes.. I dont worry about my BMW - the paint on that thing is snow proof.
Old Oct 25, 2019 | 11:36 PM
saplumr's Avatar
saplumr
Actual race cars don’t have rubber sway and control arm bushings, they have poly which won’t be affected.
To Winter Storage Question
Old Oct 26, 2019 | 01:29 AM
USA1 427's Avatar
USA1 427
SW Pa. here, and we get brutal winters. Unheated garage with a cement floor. I put down a rubber floor made of those interlocking rubber mats, then I put down Tire Cradles and drive up onto them. Add Stabil to the FULL gas tank, treat my leather surfaces well, hook up a trickle charger, add a few Bounce dryer sheets in the motor and under the car, then cover it with a super soft set of flat sheets sewn together to cover it end to end, then cover it with my Vette cover, pull it down all the way and over the tailpipes, etc. And that's it.
Old Oct 26, 2019 | 05:38 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Old Oct 26, 2019 | 05:58 AM
JustGoFly's Avatar
JustGoFly
I pull my lawn furniture off the deck, drop the table between the Vette and the garage door, in it's side to protect against any snow that could blow in. I also have room to slide the grill in there.
