CD player.
Old Oct 26, 2019 | 02:52 PM
buzzgunny's Avatar
buzzgunny
5th Gear
Default CD player.
2008 corvette, CD player sometimes works.I live in Volusia County,Fla. Where can I take it to get it fixed.
Old Oct 27, 2019 | 12:00 PM
SK '08's Avatar
SK '08
Have you thought about upgrading the stock radio/ cd player ? I did, and I ain't looking back.
I installed one of these like 2 yrs ago. https://www.crutchfield.com/S-dBOn7G...C-6200NEX.html
Old Oct 27, 2019 | 01:25 PM
4SUMERZ's Avatar
4SUMERZ
Have you tried running a claner CD in the player to see if it would clean the laser lens? Try that first. You can also get a can of air and shoot it into the player slot. That may dislodge some dust from the lens, and or mirror.
If that doesn't work, you can take the top off the Nav unit to get access to the top of the CD player, where you can manually move the table and clean the laser lens with a Q tip and alcohol.
Good Luck
Old Oct 27, 2019 | 04:38 PM
Bob Paris's Avatar
Bob Paris
4Sumerz gave you good advice. You might better describe how the CD player is not working. Such as you can't insert a disc, the disc is not readable etc. Forget about having the unit repaired since it is doubtful you can find a tech to work on such a piece of equipment and even if you did, their labor fee, plus labor to remove & reinstall the unit would be prohibitive.
To CD player.
