Low beam headlight relay
Old Nov 14, 2019 | 06:20 PM
bobnjudy's Avatar
bobnjudy
Default Low beam headlight relay
The low beam relay on my Z06 is misbehaving. I am having trouble finding a replacement for the number 12193606. There are relays for the AC clutch available numbered 12193604. Does anyone know if they are interchangable? I can not find the specks on either one.
Old Nov 14, 2019 | 06:40 PM
jamieo's Avatar
jamieo
https://suncoastcyclesports.com/08-c..._content=Test1
Old Nov 14, 2019 | 07:11 PM
bobnjudy's Avatar
bobnjudy
Thanks. I'm looking for new if I can find it. This would be my 2nd choice.
Old Nov 14, 2019 | 07:18 PM
jamieo's Avatar
jamieo
D1741C at Advance Auto Parts
How about this one??
Old Nov 14, 2019 | 09:09 PM
bobnjudy's Avatar
bobnjudy
It looks like that can substitute; thanks, that looks like it will work.
Old Nov 15, 2019 | 01:44 AM
owc6's Avatar
owc6
Ok, this might sound like, or actually be a dumb question, but has your car had the low-beam inop recall done??
Old Nov 15, 2019 | 12:18 PM
bobnjudy's Avatar
bobnjudy
It is not a dumb question, and in fact the recall work was done by the local dealer 2 months ago. I am suspecting that the issue is in the connector of the relay since I can wiggle the relay and make it work, but I am going to replace the relay just to cover the bases. If none of this works, I will have to take a look at the dealers repair work.
Old Nov 15, 2019 | 12:26 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
I would check that they screwed down the fuse block tight, there are 3 silver screws that hold it down running down the middle, make sure they are tight, I had an issue where they weren't and it made the low beams not work right. Once I tightened them up it was fine.
Old Nov 15, 2019 | 02:47 PM
bobnjudy's Avatar
bobnjudy
OK thanks; I just did that along with checking the contacts which look OK and replaced the relay. It is all working now and not intermittent when I wiggle the relay so that may have been the issue.
To Low beam headlight relay
