Replacement Shocks
Old Nov 20, 2019 | 08:30 PM
midlifetoy1's Avatar
midlifetoy1
Default Replacement Shocks
I have a 2012 CentGS in need of shocks. As its my daily driver, I can't come up with a logical reason to pay $1200+ for new ride control shocks. Can anyone provide information
and opinions on good replacements. I know that I will have to install the simulators, so that is not the issue. I am considering the QA1 non adjustable,
(daily driver, remember?) and coil overs would also be a bit of overkill. I like the QA1's vs the Bilstein as they are rebuildable.
Any & all help will be appreciated
Old Nov 20, 2019 | 08:41 PM
89Roadster's Avatar
89Roadster
I put the Z06 shocks all around on mine, pretty sure a few others have done the same. Don't waste money on the simulators, find somebody with a Tech 2 clone, takes 5 minutes to code them out
Old Nov 20, 2019 | 08:45 PM
Iceaxe's Avatar
Iceaxe
^^^What he said. The Tech 2 is the correct way to remove the mag ride shocks.
Old Nov 20, 2019 | 10:56 PM
h8snow's Avatar
h8snow
Why do you need to replace you ride control system?
Old Nov 21, 2019 | 12:22 PM
4SUMERZ's Avatar
4SUMERZ
As mentioned, get a good set of Bilstein shocks of your liking, get the Mag shocks removed from the system with a tech II. A dealer can do it if you don't know anyone with a clone. They may charge you an hour of labor, but still cheaper than buying simulators.
Good luck
Old Nov 21, 2019 | 12:46 PM
bravo29's Avatar
bravo29
Because if you dont use the same electronic shocks your vette limits your speed or you throw error codes.
Ill be replacing mine in February and using a tech 2. C6 Z06 is the ones ill be using.
Old Nov 21, 2019 | 01:24 PM
h8snow's Avatar
h8snow
Still do not understand why the need to replace the MRC system and go backwards with old school suspension.
Old Nov 21, 2019 | 01:36 PM
bravo29's Avatar
bravo29
They leak and each one is $400-$500 EACH. So instead of paying $2000 (plus labor for some people) for shocks that dont last as long as normal shocks. Amazon 4- z06 shocks $230 with prime or $400 for set of Bilstein's with Prime. I rather go old and save then pay that much and have them go out again.
Mine right now are leaking and I bounce to much. In my C5 when I did it they were leaking and I could feel every bump on the road.
Went to C6 Z06 shocks and more of a stiff performance ride that felt smooth.
Old Nov 21, 2019 | 03:07 PM
h8snow's Avatar
h8snow
Bet your MRC shocks are fine. They do seep and so do Bilsteins might read the GM service bulletin about trace oil on shock body. My opinion that MRC is one of the best suspensions on the market might get a hold of Jim Mero and have the new reprogramed controller installed. Good luck.
Old Nov 21, 2019 | 08:36 PM
LowRyter's Avatar
LowRyter
Do they bounce when set on soft?
Old Nov 21, 2019 | 10:21 PM
jorgez28's Avatar
jorgez28
What is the right part number for Zo6 shocks?
Old Nov 22, 2019 | 09:03 AM
bravo29's Avatar
bravo29
both settings I feel like I am in a low rider BOUNCE BOUNCE BOUNCE BOUNCE BOUNCE BOUNCE BOUNCE BOUNCE BOUNCE BOUNCE BOUNCE BOUNCE. And its not a stiff bounce its a low rider boing boing boing till it stabilizes.
Old Nov 22, 2019 | 10:34 AM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
I put the Bilstein B8's in mine, I like them.
Old Nov 22, 2019 | 07:51 PM
midlifetoy1
Thanks to all that replied.
For those wondering why I'm going old school, my mag ride shocks were leaking really bad. Car bounced nonstop. On the lift, oil covered the shocks. I considered the Bilstein's,
but decided on the QA1 non-adjustable shocks. Chose these because they are rebuildable and went non adjustable as the car is my daily driver, street driven only.
I have the simulators and will probably go with them as I've not found anyone with a tech 2.
Anyone used the simulators, or this brand shock absorber?
Having everything installed on Monday.
To Replacement Shocks
