CD Initializing message, radio won't work
Old Nov 22, 2019 | 07:44 PM
gwyliecoyote's Avatar
gwyliecoyote
Default CD Initializing message, radio won't work
I'm posting the solution to this issue since I couldn't find it on a search. I have an '05 Z51. The mechanic installed a new radiator and disconnected the battery during the process. When I picked it up the radio display said "CD Initializing", and the radio wouldn't work (or the CD). It is important to fix this condition as it WILL DISCHARGE YOUR BATTERY if you leave it in this condition over night even with the car turned off!!!! I disconnected the red battery cable for 5 minutes and then reconnected it. In my case the radio started playing on its own and all was well. The windows have to be re-registered as usual when the battery is reconnected. If it doesn't work the first time I would try it again. If it still persists I would have the battery checked.
Old Dec 7, 2021 | 09:12 PM
gwyliecoyote
Thank you so much for posting this solution!! It was driving me crazy trying to figure out how to deal with the "CD initializing" message and the battery being discharged! You da man!!
