Low voltage
I hope it not the alternator this soon. Also Battery was replace in Nov. 2018.
It a 2008 C6 Corvette.
Put the battery on a tender over night and check the voltage when you pull the tender off. The battery should be 13.2'ish if a AGM, and should be 13.7 if a standard lead cell.
Start the car, turn off the lights/radio/AC, and the voltage with the motor idling should be 14.7V DC with the case of the alternator as the ground, and the terminal under the rubber boot on the back of the alternator as the positive source.
Now go to the battery with the engine still idling and check the terminal with the muliti meter set to DC 20 volt, and should have 14.5 volts on the battery at the termials.
Pop the engine fuse box cover, and using it terminal at the positive source, start with the battery negative terminal as the negative source first, then next the alternator body as the negitive source, should still have 14.5 volts.
If good at the alternator, but low at the battery and engine fuse block, you have a problem with the positive cable that goes from the alternator to the starter solenoid terminal (corrosion or the nut is loose). If you get 14.5 using the alternator as the ground, but lower voltage using the battery terminal, then cable from the battery to the engine block just above the starter has a problem (again either corrosion, or loose bolt).
That out of the way/have 14.5 volts at the engine fuse block terminal, time to check the rest of the system from the engine fuse block to the modules themselves in the car.
The low down is the power goes from the engine fuse block, to the BCM, then out to the modules. I bring this up, since the gauges on the dash are not telling the power at the dash, but the power voltage at the ECM instead. So here is where a Tech II comes in handy, since if you have low voltage at the ECM (which it's power is coming from the BCM), then you could have lower voltage on other modules in the car as well. So with a Tech II, able to read each modules voltage to determine where in the cars connectors/ground point the problem lies. If across the board, then we know that the BCM connectors and its ground point will need to be pulled and cleaned to solve the problem. If just at say the ECM, the its it connector from say off the BCM to it, and it ground point that will need to be cleaned/resolved.
So to sum it up, post your voltages at the give check areas with the DIC voltage, and should be able to come up with a quick fix to the problem.
