Crazy hatch problem
A few of the vendors sell helper springs to give the hatch a boost when you pop the latch.
The Remote Control Door Lock Receiver (RCDLR) is found behind the dash atop the center air ducts. The back up keyless entry back up antenna is found in the glove compartment, behind the dead FOB Slot.
There is a keyless entry antenna found on the right B pillar, one found on the left B pillar, and one in the rear hatch compartment near the latch assembly.
It is quite possible that the antenna for the rear compartment is not getting the voltage signal to tell the receiver to open the hatch. That can be checked at the 2 wire connector of the antenna. All 4 antenna connctors are the same (12162017) but each antenna connector has different wire colors. The rear one is PK and PK/BK
The closest antenna should pick up the FOB signal within an approximate 1 meter range.
By opening the door, that puts you in close proximity of the left B pillar antenna, and also the back up antenna behind the glove box, thus why the hatch will open in that area.
This is my theory, and it could be completely wrong. Next time, try opening the hatch when you get close to the left B pillar, prior to opening the door.
Here is the diagrams of the 4 antennas in question and locations. All antennas are the same part - Antenna - GM part # (25888495)
Hopefully this will allow you to troubleshoot and fix the issue. Good Luck
Are you the original owner of the car?
maybe the hatch release was triggered while in my pocket ( getting out of the car ). but I doubt it.
I can hear it when it releases ( at least when I'm nearby ).
What's surprising is it hadn't happened sooner.
Quite common rear hatch button accumulates dirt/grime over the years.
Dirty switch fails to make contact failing to trigger hatch mechanism.
If interior switch releases hatch, it's rear button/switch close above lic plate.
Mine got so bad neither fob or interior switch would open it.
DIY remove switch, disassemble/clean & replace & that'll fix it; or, buy a new switch (what I did).
Choose your poison.
Weather does not make a difference, time away does not make a difference.
Deck lid will not pop using the release button on the car, until I open a door and the door always releases with FOB in pocket.
Cleaning the switch is good advice, new FOB batteries are also a good idea.
Good luck.
I also saw a noticeable improvement in the hatch popping open on my 2005 when i installed new struts, if i had to venture a guess im thinking maybe there 's a small vacuum in the car with the doors closed, and when the driver's side door is opened the vacuum is removed and with weakened struts it's enough to create a problem, only guessing though.
Weird issue.......
