Shocks
Old Dec 7, 2019 | 04:45 PM
Akavetteguy's Avatar
Akavetteguy
4th Gear
Default Shocks
I am looking at putting new shocks on my 2008 z51 vette. What are the best ones to get. Thank you.
Old Dec 7, 2019 | 04:47 PM
wlittle49's Avatar
wlittle49
I am looking at Koni and Bilstein. The Koni are twice the cost of the Bilsteins and I need to know why?
Old Dec 7, 2019 | 06:25 PM
Boomer111's Avatar
Boomer111
Love my Koni FSD’s, pricey though. Much better than the Base set up and not as rough as Z51 ride. I have the Z51 sways and upgraded end links. Car for street is great although wife thinks it is rough.
Old Dec 7, 2019 | 07:33 PM
LowRyter's Avatar
LowRyter
Bilstein B6. That's the consensus on the board. I have them on my base '08 C6 6SM.
The B8 are pretty stiff and lower the car.
Old Dec 7, 2019 | 07:40 PM
Sphurley's Avatar
Sphurley
I have a set of:
DRM valved Bilsteins Great ride compared to stock
PFADT Johnny O'Connell
Currently running Koni Sports for AutoX
Old Dec 7, 2019 | 11:29 PM
BackInBlack05's Avatar
BackInBlack05
Recently went through the research (here and elsewhere) for my '05 Z51. I haven't installed them yet but got a set of Z06 shocks.
My thread, but there are others:
https://www.corvetteforum.com/forums...or-05-z51.html
Old Dec 8, 2019 | 12:01 AM
Dano523's Avatar
Dano523
My testing grounds for shock is off camber corners with light road chop.
OEM z51 shocks, the back end will chatter out/ end lets loose in slight amounts on a hard drive out since the shocks can not keep the back end planted in the chatter.
B-8s and DRM's, little bit better in chatter, but you still get the back end that will slightly chatter out as well (just a little slower).
Koni FSD’s hold the back in, due to the added FSD valving for these type events that allows the shocks to react/keep the back end planted to this type of chatter.
As for smoother road course work, DRM's all day long, since they hold the car more level instead.
Hence DRM's are slightly stiffer dampened B8's to hold the vets more level in the corners.
So really, just depends what you want the car to do with a fixed (none adjustable) set of shocks.
Old Dec 8, 2019 | 12:29 AM
Cherokee Nation's Avatar
Cherokee Nation
LowRyter: Are B8's the hever duty are the sport?.....Thanks
Old Dec 8, 2019 | 09:16 AM
choppychop's Avatar
choppychop
ZO6 shock upgrade from Cultrag. Under $300.
Old Dec 8, 2019 | 09:18 AM
choppychop's Avatar
choppychop
See "what did you do to your corvette this weekend" post. Good review of Cultrag on there.
Old Dec 8, 2019 | 11:58 AM
BabyBlueVert's Avatar
BabyBlueVert
Here’s several shock choices as rated from soft to firmer that was posted earlier by a member: C6 base, Z51 (some report high speed instability), Bilstein B6 (formally Heavy Duty), C6 Z06, Bilstein B8 (formally “Sport”). Another member who had driven his C6 over 200K and changed shocks 6-7 times (including both Bilsteins and inverted Pfadt’s), liked the Z06 shocks best.
On my 2008 base convertible daily driver, I recently installed the Z51 sway bars and Z06 shock combination from CULTRAG while keeping the C6 base springs. I wish I made this upgrade long ago. The only negative to me is driving more carefully through bumpy construction zones. It’s an outstanding base C6 handling upgrade on smooth road surfaces. For a DD, the Bilstein B6 or Z06 shocks may be your best bets. I may also try B6 Bilsteins on my next shock change, although have no regrets with Z06 shocks over stock OEM. Keep reading posts to help sort out what’s best for your driving needs.
Old Dec 8, 2019 | 12:05 PM
NYC6's Avatar
NYC6
Bilstein B8 for Z51 cars and already lowered cars, they don’t further lower the car but just are a little stiffer then the B6. Did them on my Z51 and they aren’t noticeably stiffer then the stock shocks but improved handling from the worn shocks.
Old Dec 8, 2019 | 01:31 PM
BackInBlack05
How does a shock lower a car?
Old Dec 8, 2019 | 01:40 PM
Sphurley's Avatar
Sphurley
Once you try to install them (you have to compress them) you will see why some lower more than others.
There is a lot of pressure in the shocks, some more than others, so some take some of the load off the springs and keep the stock height.
There will be those that argue this and that's fine. I have put three different sets on this season and it does make a difference.
You can have my DRM's for $200.00, there might be 500 miles on them. Great ride just a little too soft for AutoX
If you want a stiffer ride the Pfadt Johnny O's would be $350.00 and also have about 500 miles.
Old Dec 8, 2019 | 04:46 PM
Iceaxe's Avatar
Iceaxe
I'm interested in your DRM's. I sent you a PM.
Old Dec 8, 2019 | 04:49 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Wondering why you think you need new shocks.
Tom
Old Jun 23, 2021 | 03:46 PM
OlyC6's Avatar
OlyC6
St. Jude Donor '16-'17, '19
Glad to hear it worked out well for you. Wondering if anyone following this post did a comparo of Bil B vs. QA non-adjustable and found one better than the other?
To Shocks
Old Jun 23, 2021 | 11:04 PM
Lee Cromwell's Avatar
Lee Cromwell
I've got an 08', Z51 manual and went with the B-8's and couldn't be happier. Installed all 4 myself in about 2 hrs total, easy. Great improvement, feels firmer, not stiff, just firmer. It did Not lower my car at all! I made measurements at each corner and my height stayed exactly the same, made measurements for numerous days in a row to make sure they didn't ' settle in'... So who ever says B-8's are or will lower the height is wrong.
Old Jun 23, 2021 | 11:48 PM
vezePilot's Avatar
vezePilot
I just finished putting a set of DRM valved Bilsteins on my 07 Base. Along with the Z51 Bars I installed earlier, I am VERY HAPPY with the improvement.
Handling is amazing, ride quality is great, and I didn't notice any lowering effect. No Downside to DRMs. And they are about $525 for the set.
Well, except that they are having difficulty keeping up with demand. But the wait WAS WORTH IT.
Old Jun 24, 2021 | 05:47 AM
Iceaxe's Avatar
Iceaxe
The only good thing about this two year old thread was I picked up a set on nearly new DRM's for $200... Hahaha
