C6 base future
Old Dec 15, 2019 | 12:36 AM
kite167's Avatar
kite167
Default C6 base future
Ok. So I'm planning mods for my 2009 base c6 w 33k miles. I thought I was gonna do: headers Xpipe Intake and tune and call it good. BUt then my buddy w a 2018 zo6 insisted j wouldnt be happy unless I did a procharger.
I want a reliable car, that makes a lotta power. One of my questions is, are headers, Xpipe, CAI and tune prerequisites for a procharger? Or are they not supporting mods? I would like to go one step at a time. But dont want to spend money twice... thanks in advance.
Old Dec 15, 2019 | 01:12 AM
farmington's Avatar
farmington
Everything but the CAI will work with the procharger. Obviously you will need a retune with the blower.
Old Dec 15, 2019 | 01:21 AM
kite167's Avatar
kite167
so I would need all those things for a procharger? All supporting mods?
Are they necessary for a procharger?
wanna know if I'm building towards that? Ir it's more expensive that way...
Old Dec 15, 2019 | 02:15 AM
FAUEE's Avatar
FAUEE
Not need, but want. You also might want an edelbrock or other blower. Your bolt ons are a great start, and you may find its all you want out of it. If mot, no big deal.
I wouldnt do an intake personally. The zr1 uses the szme intake, it isnt a restriction and the aftermarket ones are expensive as hell.
Old Dec 15, 2019 | 02:23 AM
helomech's Avatar
helomech
My 2009 is putting 450 whp down with just intake, cam and headers. I am very happy with the power, and have no plans in the near future to add more power. Might change in the future, but very happy with the power. My future mods will be handling based mods. With traction control off, I can't use all the power in 1st or 2nd.
Old Dec 15, 2019 | 03:19 AM
Verrückt ZR1's Avatar
Verrückt ZR1
Sounds like you need better tires.
Old Dec 15, 2019 | 12:02 PM
helomech's Avatar
helomech
I have bf Goodrich sport comp 2's, but don't think any street tire will give enough grip to use all the power. Not in first for sure.
Old Dec 15, 2019 | 12:13 PM
kite167's Avatar
kite167
nice. What's the power difference between just headers, and headers/cam?
does the cam make it obnoxious to drive around with?
Old Dec 15, 2019 | 12:20 PM
helomech's Avatar
helomech
Well with a 15% drivetrain loss, that would make it 510 +/- at the crank, and the stock car put 436 at the crank. Driving around with the cam took some practice, but now I hardly ever notice it, unless I am idling around and don't let the clutch out correctly. It does not like to cruise around at less than 1500rpm, it will give you a slight rocking back and forth, but above 1500 I don't notice anything.
Old Dec 15, 2019 | 12:48 PM
Verrückt ZR1
I'm making over 600rwp, and my Toyo R888R's hold the power very well. Stickier compounds are the way to go.
Old Dec 15, 2019 | 12:55 PM
helomech's Avatar
helomech
Yes, but how long do they last. I have only had my car for 3 months, and already put 5k miles on it. My biggest concern isn't top grip. I drive 400 miles one way to work, so I need a compromise. Also is that with all traction control turned off? Not saying you are wrong, never had 600 hp, but I do find it hard to believe that tires on the street can hold up to 600 hp. No doubt on a track, but does it really hold up in street conditions?
Old Dec 15, 2019 | 01:10 PM
kite167's Avatar
kite167
got it. Just watched your dyno video too. Car looks awesome!
Old Dec 15, 2019 | 01:27 PM
helomech's Avatar
helomech
thanks, I love it. Thought I would want more power, but I don't feel I can use more. Want suspension mods next.
Old Dec 15, 2019 | 01:51 PM
captain vette's Avatar
captain vette
ZR1 tranny ratio are much different (taller) than LS3 tranny ratio.
Old Dec 15, 2019 | 02:22 PM
helomech's Avatar
helomech
See, no traction. And I just rolled into it.
Old Dec 15, 2019 | 07:14 PM
Verrückt ZR1
So long as they're heated, they hook very well. You hit the nail on the head, though. They'll only last 6k-8k miles. I chose to sacrifice longevity for performance, but then again, I hardly drive the car. Everything is a trade-off, they say.
Old Dec 15, 2019 | 07:37 PM
saplumr's Avatar
saplumr
https://youtu.be/83kuCuZowgc
That is not "rolling in to it" and you have horrible tires!
To C6 base future
Old Dec 15, 2019 | 08:12 PM
helomech's Avatar
helomech
I was in gear, and just went to the floor. Didn't stomp it down. Once it broke loose I just kept it going. The tires are okay on some roads, others they suck. Lafeyette la, roads really suck. S decent asphalt road and they do a bit better.
I would rather not change ties 4 times a year.
Old Dec 15, 2019 | 10:53 PM
73DBG's Avatar
73DBG
You most certainly can just throw a Procharger or A&A or ECS kit on the car with everything else being stock, that’s what they made the kits for. Now if you want to get everything out of the blower a lot of other mods are needed and certainly beneficial.
Drivability will be based on cam/clutch/flywheel/tune
How much power do you wanna make? And what’s the primary use of the car gonna be? Do you know which type of blower you’d prefer? Intended use may dictate a lot of these questions, ultimately it comes down to what everything in life already does....💰💵
Sky is the limit is the cash is available
Personally I would want my Corvette to be my daily, definitely not a modified one making decent power which I’d say is north of 600whp, but that’s just one dudes opinion. You definitely can daily a vette or one making decent power I’d just rather not. Don’t worry about drive train loss or crank HP, it’s useless information in the mod world. WHP is the only the needed.
Old Dec 15, 2019 | 11:11 PM
hubes's Avatar
hubes
If you're considering a blower you'll definitely want 1-7/8" headers, and don't waste your money on a CAI. I think you should get the headers and tune, and take it from there
