e85 sensor info please!!
Old Jan 8, 2020 | 10:16 PM
sandman0125's Avatar
sandman0125
Default e85 sensor info please!!
Thank you everyone for all the help. I have the ecs1500, ID1050 injectors and meth kit on the way. Car is broke down (removing the rack sucked) and also waiting on the ecs pin kit in the mail. I'm good to go on everything. But while I have it broke down I decided to do go a step further. I am about to order the ecs e85 stage 1 fuel system. I haven't done much research on this since I was going to wait 6 months or so. The install seems pretty easy. I need to know where to purchase a sensor. And if there is one y'all recommend. I have seen apps as well. I have dash logic and didn't know if there was something that would work with that. Thank you in advance and roll on!!!!!
Jason
Old Jan 9, 2020 | 12:01 AM
Dano523's Avatar
Dano523
Kind of lost, since you are not picking a direction and just going with it.
Hence if your going to run E85, then just install the E85 sensor, needed larger fuel pump, and the rest you can do in the tune tables by turning on the E85 table already in the tune.
If your going to run petrol with a meth kit, then run that with the larger needed fuel pump instead.
Hence you don't need to run a meth kit with E85 fuel. E85 already has a octane rating of 108 (and water), so no reason to run the meth kit to increase the e85 octane rating higher.
Old Jan 9, 2020 | 02:13 PM
Creatre's Avatar
Creatre
Purchase the DSX flex fuel sensor or make your own.
To e85 sensor info please!!
