Coolant change or flush?
Old Jan 15, 2020 | 03:34 PM
feastersss's Avatar
feastersss
C6 of Year Finalist (stock) 2019
Default Coolant change or flush?
I know I've seen a few post on here about this....My '11 GS has 12K miles, I purchased it last April with 9300 miles and I'm positive it has the original coolant, should I flush the system, or let it drain and refill with a 50/50 mix of Dexcool?
Old Jan 15, 2020 | 03:51 PM
saplumr's Avatar
saplumr
I have my GM dealer use their automatic recovery and fill system. Not overly expensive and saves a lot of hassle.
Old Jan 15, 2020 | 04:20 PM
Red08's Avatar
Red08
When I had my C6, I changed the coolant myself. It was easy to do. Make sure you use distilled water. I used a 50/50 mix of water and anti-freeze.
Old Jan 15, 2020 | 04:52 PM
Legend Rider's Avatar
Legend Rider
Just a question, why use distilled water? I have never heard that. I have always just use plain tap water. Thanks.
Old Jan 15, 2020 | 04:58 PM
Josephu's Avatar
Josephu
Tap water is full of minerals. distilled water is not. I use reverse osmosis out of the house sink.
Old Jan 15, 2020 | 06:04 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
The cost is little, and you no it's done properly serviced.
MY motto, is if you can afford a Corvette, why are you putting in regular gas to save a buck, and why not have coolant changed properly.
Old Jan 15, 2020 | 06:17 PM
88redconvert's Avatar
88redconvert
I have a 2012 and will drain and refill mine the first nice day that comes along but I really don't think it's necessary. It has the original coolant in it. I'll also use distilled water.
Old Jan 15, 2020 | 06:19 PM
steig's Avatar
steig
Distilled water is like .99 cents of gallon. Thats what I used.
Old Jan 15, 2020 | 07:22 PM
Mad*Max's Avatar
Mad*Max
I would just do the change at home by opening the petcock and draining out as much as possible. I use tap water as the manual says to use potable water, some folks say that distilled water is not good as it has no minerals and the coolant will "attack" the metal parts in the cooling system. I am not a chemist so I just follow the manual.
Old Jan 15, 2020 | 07:43 PM
saplumr's Avatar
saplumr
I'm with you on potable water but potable water is defined as any safe to drink. Distilled water is potable but most people would not like the taste but it is still potable. I know for a fact dealers use tap water so the distilled water to me is unnecessary.
Old Jan 15, 2020 | 07:54 PM
feastersss's Avatar
feastersss
So use straight coolant a potable water vs 50/50 mix?
Old Jan 15, 2020 | 08:00 PM
indyblue67's Avatar
indyblue67
I like to use distilled or at least soft water. You won't get crusty calcium buildup in places the cooling system might seep (host connections, water pump housing, internal cooling passages, etc) and it is ph neutral so it won't attack the aluminum block.
Old Jan 15, 2020 | 08:09 PM
hawkgfr's Avatar
hawkgfr
We used distilled water for batteries but not radiators back in the day... Mine is original too from 2012. I think its about 129 for flush and fill at dealer?
Old Jan 15, 2020 | 08:11 PM
BadAV's Avatar
BadAV
I've always used tap water, as the antifreeze manufacturers typically say it's OK. Open the petcock, drain the radiator. Close the petcock, fill through the overflow tank with water, start car and top off as the overflow tank goes empty. Let the coolant circulate for a while after the thermostat opens up. Shut the car off and drain the radiator again. Fill again, repeat the run time. This time when you drain the radiator it should be pretty much just water. Close the petcock and refill the system with 100% Dexcool - the block is full of water only and contains pretty close to 50% of the system fluid capacity. So by filling the radiator with Dexcool you end up pretty close to a 50/50 mix. That's the way I have always done it and never had a cooling system issue. I have owned several vehicles for as long as 14 years. I have always changed based on the OEM or coolant manufacturer's recommended timeline; I believe that is 5 years for Dexcool. It's 10 years for my F-150 and the wife's Charger.
Old Jan 15, 2020 | 08:13 PM
corvettejoe09's Avatar
corvettejoe09
This has been debated for years. Everyone has different opinions. I found a great solution. For years I been using GM Dexcool 50/50 premix. Done, end of story.
Old Jan 15, 2020 | 08:24 PM
saplumr's Avatar
saplumr
50%water (of your choice)/ 50%antifreeze is standard. Premixed jugs sold by auto stores is a 50/50 mix.
Old Jan 15, 2020 | 08:25 PM
Kenny94945's Avatar
Kenny94945
But the OP question concerning the 5 year Dexcool life.....
Drain and refill or Flush
My Vote: Flush as I understand Dexcool can "gum up" with age.
Yet drain and refill is a whole lot easier if DIYing.
To Coolant change or flush?
Old Jan 15, 2020 | 09:25 PM
tw78911sc's Avatar
tw78911sc
If the coolant isn't orange, I'd flush a couple of times, if orange, drain/refill IMO
Old Jan 16, 2020 | 09:12 AM
GS982's Avatar
GS982
Finalist 2021 C3 of the Year - Modified
2018 C6 of Year Finalist
Old Jan 16, 2020 | 10:43 AM
FatsWaller's Avatar
FatsWaller
From the DeWitts FAQs "Aluminum is very sensitive to minerals and chemicals in all sources of water, and only distilled water should be used" to mix with the coolant. They go on to say either that, or use the premixed stuff. So, when the DeWitts rad was put in, the coolant system was flushed to purge all of the old coolant, including the heater core, and distilled water was used as recommended. I'd be avoiding tap water, since most of it is chlorinated. There are additives to Dexcool which fight corrosion but in doing so, they get used up. Hence the need to change it at the 5 year mark. Even if you don't have a DeWitts rad, all the OEM roads have aluminum cores. Some have aluminum end tanks.
