Time for new shocks?
Old Jan 23, 2020 | 05:27 PM
SUP54's Avatar
SUP54
Default Time for new shocks?
I have a 2007 Corvette coupe / base with 28,000 miles. I purchased the car two years ago. I have changed all fluids (transmission, differential, power steering, antifreeze, oil, etc.) but have not touched the shocks. Car is not daily
driven.
I suspect shocks are original to car. Do shocks wear out / sit lower over time (12-13 years) or is strictly mileage?
Car rides goods, seems to sit just fine. Just wanting to see opinions regarding changing shocks.
SUP
Old Jan 23, 2020 | 05:34 PM
wayback's Avatar
wayback
You should be OK, but your getting close. My OEM shocks lasted a little over 30,000 miles...as have every other brand I've tried.
Maybe lowering my car puts undue stress on them? IDK.
Old Jan 24, 2020 | 05:55 PM
joliett's Avatar
joliett
Just for all information, my 2008 with 170,000 miles has Magnetic shocks....still great!
Old Jan 24, 2020 | 06:10 PM
OlyC6's Avatar
OlyC6
St. Jude Donor '16-'17, '19
I'm in the same quandary... my '07 only has 30K on the clock.. has the FE3 Suspension System Sport... for the most part "seems" to be OK... but with the number of years... considering replacement shock options. Seem like a lot of owners have a preference for the Bilstein HD direct-replacement. So interested in what gets posted (replies).
Old Jan 24, 2020 | 09:28 PM
ProCycle's Avatar
ProCycle
FYI - shocks have no effect on how a car 'sits'. The car is held up by the springs. The shocks keep suspension movement controlled.
Old Jan 24, 2020 | 09:50 PM
FAUEE's Avatar
FAUEE
Hope. Testing shocks is easy, push down firmly on a corner of the car. When you release, if it goes back to normal, they're fine. If it bounces back and forth a few times before settling, they're shot.
Old Jan 25, 2020 | 01:38 AM
wayback's Avatar
wayback
While I agree this is mostly true, on a lowered C6 new shocks will raise the ride height and it will lower as the shocks weaken. My car sits about 1/2 lower when the shocks are just about shot.
Old Jan 25, 2020 | 09:29 AM
ProCycle's Avatar
ProCycle
Yes. Technically, the nitrogen pressure inside the shock will contribute *some* lifting force. But as you pointed out the effect is very small. The lifting force is probably in the neighborhood of 40 pounds - on suspension that carries 800-900 pounds at each wheel.
Old Jan 25, 2020 | 01:59 PM
buckmeister2's Avatar
buckmeister2
And...unless they are subjected to external fluids that could cause damage (saltwater, etc.), they do not "age", unless a car sat in a barn for 20 years, and was never moved. I cannot see a reason for replacing shocks on a daily driver until at least 50K. I know that is too long for a lot of people. And, some folks think shocks are the same as struts, and they aren't.
Old Jan 25, 2020 | 02:17 PM
FAUEE's Avatar
FAUEE
FWIW, the shocks on my truck are original and have 120k on them, still working fine too. IMO, people like to replace shocks as a feel good measure, and the butt g meter is usually pretty favorable to the new confidence new shocks create.
Old Jan 25, 2020 | 02:20 PM
lobstah24's Avatar
lobstah24
2012 here...just went over 20k miles last fall. I'm putting these on to stiffen up things a bit.
https://www.amazon.com/gp/product/B01BOPK5RC/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B01BOPK5RC/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
Old Jan 25, 2020 | 02:41 PM
buckmeister2
My '01 Silverado 4x had the fac. shocks until about 150K. Compared to the ones we had on the 60's and 70's cars, shocks have come a long, long way.
Old Jan 25, 2020 | 03:53 PM
4SUMERZ's Avatar
4SUMERZ
I have over 100K miles on my car, and replaced my OEM, with another of the same at approx 50K miles.
I replaced those those last Spring with Bilstein's
Old Jan 25, 2020 | 07:38 PM
BackInBlack05's Avatar
BackInBlack05
Z51 with 140K. Just replaced with GM Z06 shocks. Originals were prolly going for awhile (slow process), but eventually any bumps/seams/holes felt really "crunchy". Never did "bounce". Vastly better with the new shocks. While stiff the jarring/crunch is much better managed.
Old Jan 26, 2020 | 12:12 AM
gpruitt54's Avatar
gpruitt54
How do you know when it is time to replace the shocks? What are the indications for worn shocks?
Old Jan 26, 2020 | 02:02 AM
Dano523's Avatar
Dano523
On the base model, you can go a lot longer before you will feel the difference in the corners as the shocks start to give up the Ghost. Its not that the base model shock suck, it just that car has a softer suspension, so just harder to tell as the shocks do start to go softer in dampening instead.
On a Z51 (car built for autocross from the factory), you can start to feel the shocks give on the ghost in hard corners around the 30K marks (as you lap times increase as well)..
Old Jan 26, 2020 | 08:02 AM
seijack's Avatar
seijack
I would say that on Corvettes that usually lead a pretty pampered life unless they are used as DD I would go with 75-100K miles. Shocks dampen the motion of the springs so the biggest indications of needing new shocks are excessive bouncing when going over swells or dips at highway speeds (3 bounces or more) or excessive harsh roughness when hitting potholes in town. Shocks go so slow and gradual it is hard to tell when they need replaced.
To Time for new shocks?
Old Jan 26, 2020 | 09:29 AM
FAUEE's Avatar
FAUEE
Push down on a corner. If it goes right back, shocks are fine. If it bounces up and down before settling, theyre bad.
Old Jan 27, 2020 | 01:02 PM
LowRyter's Avatar
LowRyter
some of us replace the OEM shocks with Bilstein B6. Not essential but nice. If you're OEM shocks aren't leaking they're likely fine. You might like the ride from B6.
Recommend that you raise the air pressure to 32LB with new B6.
Old Jan 28, 2020 | 08:58 AM
PCMusicGuy's Avatar
PCMusicGuy
I replaced the shocks on my DD 07 (Z51) at around 70k miles with the DRM Bilsteins. I'm now at 155k and I think the OEM shocks felt better at the end of their life than the BIlsteins do now. I'm gonna try the Koni Special Actives (replaced FSD model) next.
