Header Bolt Torque Specs
Old Feb 7, 2020 | 10:25 PM
Checkered Past's Avatar
Checkered Past
Default Header Bolt Torque Specs
Is this correct?
11ft lbs first pass
15 ft lbs second pass
have read also 18 ft lbs second pass??
tighten from center out?
Thanks!
Old Feb 7, 2020 | 11:39 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
When I saw the thread I was going to say 18 from memory on the LS1. Seeing as the bolts are the same I would have thought it was the same for the LS2 and LS3.
if you did not replace the bolts with new ones I would highly recommend you do so. They are chintzy little bolts notorious for breaking and getting stuck in the heads. Anything with 50,000 miles on should have them replaced as a maintenance item.
Old Feb 8, 2020 | 07:37 AM
Spaceme1117's Avatar
Spaceme1117
Originally Posted by Checkered Past
Is this correct?
11ft lbs first pass
Thanks!
I always do 11 to 12 on the first pass starting from the center and then alternating back and forth from the center out. I then do a 18 or a little more, like 20 on a second pass, center out. Definitely a good time to upgrade to ARP bolts. Also, make sure to use a bit of anti-seize on the bolts.
Old Feb 8, 2020 | 09:21 PM
FatsWaller's Avatar
FatsWaller
If you care about correct torque, then you have over-tightened the bolts up to double. 18 is the dry torque spec. I'm not sure what's in anti-seize, but it kind of looks like graphite. If so, 9 ft-lbs would have been the spec. Probably won't hurt the bolts, but what about the threads in the head? Just my .02
Old Feb 8, 2020 | 10:21 PM
K-Spaz's Avatar
K-Spaz
sometimes graphite but more often molybdenum
To Header Bolt Torque Specs
