Added Some Color
Old Feb 16, 2020 | 07:45 AM
seijack's Avatar
seijack
Default Added Some Color
I finally installed the intake covers that I ordered last fall. I did have to cut and grind in a few areas to get them to fit correctly, but I think they look good and add the right amount of color under the hood
Old Feb 16, 2020 | 09:04 AM
myredhead1's Avatar
myredhead1
Very nice. Well done.
Old Feb 16, 2020 | 09:17 AM
JABCAT's Avatar
JABCAT
Agree looks great! I painted mine myself with factory-match paint from automotive touch-up.
Old Feb 16, 2020 | 10:03 AM
Legend Rider's Avatar
Legend Rider
Looks Great! Whom did you get them from & why was the cutting & grinding needed? I'm asking because I thinking about doing the same as you. Thanks.
Old Feb 16, 2020 | 10:12 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Looks good!
Old Feb 16, 2020 | 03:38 PM
seijack's Avatar
seijack
Thanks,
I got them from RPI.
The biggest reason for the trimming Is my profession, I am a toolmaker/cnc programmer. If it isn't a perfect fit I am not happy.... These are 2 pieces, in the areas that go under the fuel rail cross over it was a very tight fit and would cause each opposite ends to pop up. I thought it would cause the double sided tape to loosen over time. The other area was on the driver's side rear cover, the cover wouldn't go under the fuel rail supply line so I just cut it off, it was never seen since it is under the coil cover so no problem.
Old Feb 16, 2020 | 03:44 PM
seijack's Avatar
seijack
NICE, is that the Inferno color? Is that the original cover and you painted it? If so I guess you had to remove the fuel rail?
Old Feb 18, 2020 | 05:12 AM
JABCAT's Avatar
JABCAT
It is Inferno Orange & the original cover. I didn’t have to remove the fuel rails, just popped them up a little to slide the cover out & back in. I’ve got a post on here somewhere walking through the process.
To Added Some Color
