'06 Starting issue
Old Feb 22, 2020 | 08:40 PM
feastersss's Avatar
feastersss
C6 of Year Finalist (stock) 2019
Default '06 Starting issue
I have a buddy that has an '06 Vert, M6, 17K miles with a new battery putting out 11.5 Volts, uses a tender when its parked. With the old battery and with the new one, its starts like it has a very weak battery, terminals are clean and tight....Could the solenoid connections be loose/broke causing this issue?
Old Feb 23, 2020 | 12:20 AM
Crow Hunter's Avatar
Crow Hunter
My '06, with only 14,500 miles had the exact same situation. Much to my surprise, it turned out to be the starter itself. I've never had a starter to bad w/ so few miles on it.
Old Feb 23, 2020 | 12:57 AM
Qshiplover's Avatar
Qshiplover
Our 2008 C6 with 160,000 miles fried a relatively new starter (about 1 yr old). The shop that replaced it said that because the exhaust manifolds cocoon the starter, it literally bakes it to death, and if you run long distances at high speeds (like a road trip, for instance, or daily driving on freeways which is how our C6 got up in mileage so high) it will be especially cruel to the starter electrics. He suggested a heat shield blanket which we shrouded and attached with stainless steel zip ties, and so far, knock on wood, still starting fine.
Old Feb 23, 2020 | 08:37 AM
feastersss's Avatar
feastersss
He said he can now hear a clicking noise inside the car along with this issue, I noticed the starting issue last year and can tell that it seems to be getting worse!
I think it's the starter!
Old Feb 23, 2020 | 10:23 AM
Mad*Max's Avatar
Mad*Max
Originally Posted by feastersss
I have a buddy that has an '06 Vert, M6, 17K miles with a new battery putting out 13.5 Volts, uses a tender when its parked. With the old battery and with the new one, its starts like it has a very weak battery, terminals are clean and tight....Could the solenoid connections be loose/broke causing this issue?
what do you mean putting out 13.5v?
Old Feb 23, 2020 | 02:16 PM
feastersss's Avatar
feastersss
Sorry, I meant 11.5/12
Old Feb 23, 2020 | 02:26 PM
Mad*Max's Avatar
Mad*Max
is this the reading off the car's gauge while in ignition mode without starting the car?
Old Feb 23, 2020 | 02:38 PM
ProCycle's Avatar
ProCycle
If this is being measured at the battery then it's basically dead. 12v is 25% charged. 11.8v is zero % charged.
If this is the display on the DIC with the engine not running then the battery is still less than 1/2 charged.
If this is the display on the DIC while the car is running then the charging system is not working.
I'll bet the battery tender has failed.
Old Feb 23, 2020 | 06:30 PM
feastersss's Avatar
feastersss
I just went and put my eyes on it, on the DIC running, it 14.2/14.3 volts!
Old Feb 23, 2020 | 06:32 PM
Mad*Max's Avatar
Mad*Max
see post 8, I will just add that it could also be the battery
Old Feb 23, 2020 | 06:45 PM
feastersss's Avatar
feastersss
Ok, I'll let him know
Old Feb 24, 2020 | 08:28 AM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
Now that these cars have a little age on them, you have to look at the starter. They had a single wire plug in on the solenoid for the start wire, this usually cooks itself and it will have a bad contact. Sometime is the starter itself and this contact is bad inside the plug housing. This is what you need to check if your battery is not the issue and the cables are tight.
Old Feb 24, 2020 | 08:33 AM
feastersss's Avatar
feastersss
We are gonna get it up on the lift real soon to look at the starter, I feel that is the issue from what I've read in the last couple of days
Old Feb 25, 2020 | 02:38 AM
badass7's Avatar
badass7
I had this problem was the Starter itself. New starter never looked back again.
To '06 Starting issue
