Plug Wires?
Old Mar 26, 2020 | 07:33 PM
Thera p's Avatar
Thera p
Default Plug Wires?
I’m changing plugs on my ‘11 GS and tore the boot on a MSD wire. Don’t like them anyway as the boot is much longer than OE. Soft and hard to get off. What 8.5 mm wires are folks using? Need to get something on order. Thx.
Old Mar 26, 2020 | 08:27 PM
jamieo's Avatar
jamieo
The OEM plug wires are hard to beat.
Old Mar 26, 2020 | 08:59 PM
LOURDESBELLE's Avatar
LOURDESBELLE
2025 C6 of the Year Finalist - Modified
Firecore50 are one of the best, in fact the best.
Old Mar 26, 2020 | 09:08 PM
h8snow's Avatar
h8snow
Oem.
Old Mar 26, 2020 | 09:11 PM
Majkowski's Avatar
Majkowski
Oem
Old Mar 26, 2020 | 09:18 PM
lobstah24's Avatar
lobstah24
+1 for the OEM wire set.
Old Mar 26, 2020 | 11:10 PM
Hitman227's Avatar
Hitman227
Magnecor is supposed to be aftermarket go-to
Old Mar 26, 2020 | 11:43 PM
Dano523's Avatar
Dano523
FYI, the oem spark plug wires, and the oem spark plugs have a higher resistance for a reason.
With low resitance plugs and wires, you can have the Coils cause RF noise in the system from not enough resistance suppression.
The RF noise makes is way back to the ECM, and since the ECM controls the voltage of the alternator, enough RF noise to the ECM, and the alternator is now putting out a much lower voltage isntead due to incorrect control from the ECM. Hence can cause the service charging system problems, when there is nothing wrong with the alternator/battery to begin with. Normally, the alternator (ecm controlling it) will put out 14.7 volts, and with bad RF noise to the ECM, have seen the same alternator put out only 12.3 volts instead.
So if a company is toting that their spark plug wires are better since they have a lower resistance, that does not hold water for the C6 corvettes since they can cause some major RF noise back at the coils/ then entire system.
Old Mar 27, 2020 | 06:20 AM
Don-Vette's Avatar
Don-Vette
A dab of dielectric grease on both ends of your wires goes a long way for ease of taking them on and off and prevent corrosion. I love my MSD wires.
Old Mar 27, 2020 | 07:21 AM
Spaceme1117's Avatar
Spaceme1117
I really like the Summit Racing LS spark plug wires. They extent the large rubber boot part that goes onto the spark plug. Allows getting a better grip to pull off the boot. As good of quality as OEM.
Summit Racing® 8mm Ignition Wires SUM-867828R
Old Mar 27, 2020 | 02:15 PM
Dans91's Avatar
Dans91
Headers?
OEM is always a great way to go when you have stock manifolds. They work great either way but the heat is what kills them. I just switched over to 2" headers and bought my first set of FIRECORE50 wires with the Promod boots..... LOVE THEM!!!! I will replace all my wires with them. They have bendable boots and have been pretty easy to get on and off and I cannot ever foresee them ripping or falling apart. I will post some pics up here in a minute to show them to you. FYI, I have already ordered another set for the Camaro and will be replacing them in the TBSS as well. :P
Old Mar 27, 2020 | 02:18 PM
Dans91's Avatar
Dans91
Here ya go!
Old Mar 28, 2020 | 01:35 PM
Dano523's Avatar
Dano523
Just a FYI, but the heat off the header tubes is going to do your spark plug wires in, in a very short time.
Would suggest that you get heat shield on the wire boots.
Old Mar 28, 2020 | 01:52 PM
captain vette's Avatar
captain vette
This
Old Mar 28, 2020 | 02:30 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
These heat protectors only work if you have DIY wires. As they have a metal ring stitched on the ends and you can’t get it over the boot. They don’t work on oem wires
To Plug Wires?
