So, does anybody know what happens when 4 Fobs have already been programmed?
Going from memory, when I did mine I believe the DIC showed something similar to "Max Fobs (Learned ?).... " That was after successfully turning the key 5 times within 5 seconds in the hatch release. You need to turn fully turn the key quickly and thoroughly. Once you do, the display will show a programming message regardless fob numbers learned, etc.
If fob 1-4 is available to be programmed, the DIC will begin showing something similar to "Ready for FOB # (which is the next number to be programmed)" Then, "FOB Autolearn, wait 10 minutes" and begin counting them down.
Just to be clear, once you have started the long procedure, all known fobs get erased. The fob numbers are then reassigned in the the order which they are programmed, regardless of the number stamped on the fob case.
