Lug Nuts Oversized?
Old Apr 22, 2020 | 11:20 AM
thehueg's Avatar
thehueg
Default Lug Nuts Oversized?
I own a 2008 C6 Base Coupe with the Z51 package. The car came with the chrome wheels. The lug nuts have a decorative cap over each nut. It appears to be aluminum but I don’t know for sure. I brought the car into Costco as I bought the tires from them (albeit in another state where I used to live) to have them repair a slow leak on my Michelin Pilot Sports. They called me out to the shop to tell me they couldn’t remove the wheel from the car because the standard 19mm socket couldn’t slide over the lug nuts very far because the decorative sleeves added just enough thickness to prevent the socket from fully engaging the lug nut. I’ve removed the wheels before and know this sleeve can be an issue. Is there a special tool/lug wrench that should be used on these lug nuts to fully engage them? Or, do you just have to accept minimal engagement and hope to not round off the lug nut?
Old Apr 22, 2020 | 11:28 AM
JABCAT's Avatar
JABCAT
You should remove the caps and then remove the lug nuts. Once wheels are put back on and lug nuts torqued appropriately put the caps back on - or just keep them off.
Old Apr 22, 2020 | 12:37 PM
VETFEVER's Avatar
VETFEVER
Replace them with standard sized nuts - there are sets for sale by members here pretty much all the time for about $20 for a set...
Old Apr 22, 2020 | 12:55 PM
LilNutSac's Avatar
LilNutSac
Were they the pointy ones?! We need to see! Yeah, I'd look for some stock ones or McGuard. Or just leave the covers off, like they said.
Old Apr 22, 2020 | 01:29 PM
Bob Paris's Avatar
Bob Paris
The caps which are not removable are tin and swell due to corrosion underneath. Common on all makes of cars including GM, Ford, Dodge & Toyota. I replaced mine with one-piece solid metal lug nuts. I did not want me, my wife or kids to be faced with having to change a tire where the supplied lug wrench would not fit over the lug due to expansion.
Old Apr 22, 2020 | 01:43 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
The "caps" are just decorative to make the lug nuts look like they are chrome. You need to use a deep socket to take off the lug nuts. If you don't you will damage the cap.
Old Apr 22, 2020 | 04:39 PM
JABCAT's Avatar
JABCAT
Good to know. I remember having similar caps that were chromed plastic on lug nuts on a Z28 I had a long time ago, & I just removed them. Perhaps these are different.
Old Apr 22, 2020 | 06:31 PM
thehueg's Avatar
thehueg
So that I can avoid an extended search, would you mind directing me to some good forum vendors for such lug nuts? There have been some less than flattering reviews of some vendors and I don’t want to get tangled up with a bad supplier.
Old Apr 22, 2020 | 06:35 PM
jamieo's Avatar
jamieo
House of wheels
Old Apr 23, 2020 | 04:16 AM
Don-Vette's Avatar
Don-Vette
https://www.westcoastcorvette.com/co...lug-nuts-locks
Old Apr 23, 2020 | 06:01 AM
irok's Avatar
irok
Sounds like he is talking about the factory nuts that have chrome covers on them.They end up being damaged by half wits using a impact wrench on them and over torqueing so that they end up deforming the chrome cover.If you use a torque wrench set for the correct torque of 100 lb/ft you will never damage them
Old Apr 23, 2020 | 07:26 AM
BadAV's Avatar
BadAV
The lugnuts on my Centennial appear to be solid. The wife's 2014 Charger has the nuts with covers, and they have not been an issue. My 2015 F-150, on the other hand, had them and they almost immediately started deforming and the correct size socket would not fit or the lugnut would get stuck in the socket. I changed out to solid Gorilla lugnuts because the last thing I want is to have a flat in the middle of nowhere and not be able to get the flat off.
Old Apr 23, 2020 | 08:51 AM
05 Wreck's Avatar
05 Wreck
Caps on oem lug nuts are stainless steel, but the ferrous metal underneath rusts and swells the cap until it possibly splits. Idiots at garages don't care and overtorque destroying any attempt to get them off later.
To Lug Nuts Oversized?
