Hi I bought a couple of sensors for my corvette c6 2005 but now I have the red light on the dash and when I use my scanner it's tell me B0090 out of range. I don't know where is the problem and how I can fix it.
Any help for this case?
Commercial grade scanners cannot read deep codes like U & I'll presume B.
Deep codes require a pro-series reader, kind dealers use and expensive.
Can try having a parts store read 'em, they use good devices.
In any event a search using 'OBDII B0090' says "A B0090 trouble code refers to the restraint (seatbelt) sensor on the left front seat." Read more at: https://www.obd-codes.com/b0090
G/L, hope it's the only code because this alone doesn't sound like difficult fix.
Thanks, I already changed the pretensioner and still have the code and the light on it. I will check all airbags sensor to verify.
