Any regrets installing Xpel PPF?
For example: if I get a scratch in the clear coat on my hood , I can buff it out (usually). If I get a scratch in the PPF on the hood, can it be buffed out without burning through or distorting the PPF ? In fact, can you even used a buffer/polisher on PPF?
Thank you,
Bob
+1 on comment about doing paint correction before application (of PPF or ceramic coating).
TX
Thank you,
Bob
We appreciate you considering XPEL protection for your beautiful C6. For your question about scratches and to your other comment, XPEL was the very first company to introduce a self-healing PPF (paint protection film) to the market back in 2011 with XPEL ULTIMATE. Currently, XPEL ULTIMATE PLU, ULTIMATE PLUS 10, and STEALTH PPF's are all self-healing, non-yellowing, and warrantied for 10 years. Parts and labor. To learn more about how self-healing works and other benefits of PPF, take a look at this video from YouTuber Engineering Explained where he goes in-depth on how PPF works including how self-healing works.
Fine swirls and surface scratches will go away from the heat of the sun, a heat gun, or a hot cup of water. Of course, PPF is not impenetrable, but for your every day wear and tear fine swirls and scratches, they should all self-heal. On the other end of the extreme should there be an accident, most insurance companies will pay to have the film replaced once the body is replaced/repainted.
If you're after extra protection, we recommend going with our newest PPF, ULTIMATE PLUS 10. This PPF is 10mils thick compared to the standard ULTIMATE PLUS (8mils thick), providing increased impact resistance and durability. The best part about it is that it's still extremely contourable and is able to be installed on any body panel, not just the front bumper.
We hope this info helps, don't hesitate to reach out should you ever have any questions or need anything.
Thanks again
OP, if you get someone who has done this for a while, they can actually wrap it around the edges versus stopping at the edge as stated above. I had the half hood when I bought the car which has half the fender also. I had the whole front done, around the edges, so no lines. More expensive but i have no regrets.
Like the other posters said, the only regret would be a poor installation
The kit on the front bumper of the C6 is in multiple pieces so you’ll have a vertical line just below each fog light. The kit also leaves a good amount of open space around the fog lights which is an area that can get hit with rocks/debris. The mirror kit has a relief line horizontal right in the center of the mirror which makes it easy to see. The same on the mirrors on my wife’s GC, they did them in 2 pieces with a very obvious seam on the top of the mirror and a good portion of the mirror is left exposed.
Maybe my expectations were too high, but for the price I expected better. As time has passed I don’t notice the seams as much. The other disappointing aspect was an Xpel rep was contacted re these issues and said that’s just the way the kits are cut.
So if you go into it understanding you’ll see some seams & not all the areas you think should be covered are covered, you’ll be alright.
One other thing - check with your insurance company to see if they’ll cover replacement if damage to the covered areas occurs. My wife’s GC got hit by a metal object that fell off a truck on the freeway resulting in the front bumper needing replaced. Our insurance, Allstate refused to cover replacing the Xpel. We had to fight with them & the body shop fought with them to finally get them to cover it. We’re still waiting for the reimbursement however.
A few things to that I've found (and others may have pointed out above):
- Get the paint corrected before having PPF put on, as once it's on every little defect is there until you pull it off.
- Find a good installer that really takes his time and is proud of his work. It's worth it.
- Also, really good installers will often not use templates (or will oversize them) and trim everything for a perfect fit.
- For the best results, have all the emblems, grills, etc removed and then reinstalled on top of the film.
- Do NOT do a half hood (or any half panel for that matter). It looks like absolute crap and everybody will notice it. Personally, I would recommend either front bumper cover and mirrors only (if you are on a very limited budget), front half of the car (probably best value) or the entire car (very nice, but also big $$).
- Some may not agree, but I like having ceramic coating put on top of the PPF. It makes for much easier cleaning.
