New radiator
May 5, 2020 | 06:06 PM
New radiator
What would you estimate the cost for a new 05 C6 with Z51 option radiator installed cost.
May 8, 2020 | 04:54 PM
Hi.
I would suggest going with a DeWitts radiator replacement:
https://www.dewitts.com/
Not a big job to change the rad out - maybe 2 hours.
I would change out the Rad hoses at that time, and replace the plastic T fitting with a brass one:
Joyway 3/8"x 1/4"x 3/8" ID Hose Reducing Barb, Tee 3 Way Union Fitting Intersection/Split Brass Water/Fuel/Air $19.99
M....
May 11, 2020 | 06:57 AM
Thanks. The shop is quoting me @ $800 for new radiator and hoses and install.
May 11, 2020 | 07:59 AM
$800. for a new GM radiator/hoses, & labor is a fair price but Dewitts makes a nice replacement all aluminum piece vs the plastic GM part
May 11, 2020 | 11:21 AM
Quote:
Originally Posted by
449er
I replaced my OEM rad with a Dewitts for two reasons: No el cheapo plastic end tanks to split, and probably 50% more cooling capacity. I also replaced all the hoses with a silicon set, which looked after the leaking 'T' problem. When Dewitts says 'Direct Fit', they're not kidding. Drops right in.
May 15, 2020 | 05:36 PM
New GM plastic radiator 441.00 labor 400.00 all new belts and hoses 160.. out the door $1,000.00. Time carries on.
May 15, 2020 | 08:52 PM
I put a Dewitt’s in my old 95. Best investment
i made. You won’t be sorry!
May 15, 2020 | 10:43 PM
You might want to look up Engineered Cooling Products. ECP. Pretty sure they are a vendor here on the Forum
you might like what you see
vetfever
