I had the wrench for the bolts that hold the plate...it came with vette. But now I can't find it anywhere and want to remove this plate and put on the required Ohio plate. Anyone know what this type of tool is called? Never seen these before. Thanks for any reply.
It is called a security screw. Local hardware or big box hardware store should have a screwdriver that will work on them. The end of the screwdriver looks like half of an H. You can see four different sizes in this set.
It is called a security screw. Local hardware or big box hardware store should have a screwdriver that will work on them. The end of the screwdriver looks like half of an H. You can see four different sizes in this set. https://www.amazon.com/ARES-70009-33...%2C191&sr=8-15
I will look....thanks! Removed one with an old protractor but would just get the screwdriver.
You can make your own tool if you have an old screw driver that is wide enough. Just use a dremel to cut out the center of the screw driver leaving you two prongs.
