Broken block. What is this?
Old May 18, 2020 | 10:54 AM
Maximus881's Avatar
Maximus881
Default Broken block. What is this?
Hey. My car is Corvette C6 2006 LS2.
I was driving a 100mp / h car when something like this came out of the engine block:
There is a hole in the block at the height of the air conditioning compressor - here:
The engine after all has a good oil pressure, it works normally. I don't turn it on for security.
It is steel, not aluminum. I have no idea what this element is:
Help.
Old May 18, 2020 | 11:15 AM
Vet Interested's Avatar
Vet Interested
Something "like" this came out of the block. So you found that piece of metal for your story. If in fact it did come out of your engine start looking for a replacement motor. Done.
Old May 18, 2020 | 11:19 AM
Maximus881's Avatar
Maximus881
I would like to know what it is, where it can be from, it does not look like piston liners or shaft element. The engine was repaired last year, forged pistons were assembled, etc. I ask to determine what is this element before I start opening the engine /
Old May 18, 2020 | 12:26 PM
Solaris's Avatar
Solaris
How did you find it if you were doing 100MPH when it came off? Did you find this rattling around in the engine bay after you pulled over to look? Might be coincidence that the part was left in the engine bay during the work done and you discovered it now.
Old May 18, 2020 | 12:31 PM
Maximus881's Avatar
Maximus881
I rode and the engine block suddenly cracked. I stopped at a gas station and called for roadside assistance. a lot of engine oil spilled out. the other day I started looking for the cause of the leak and noticed a hole in the block at the height of the air conditioning compressor And this broken element was between the engine and the air conditioning compressor
Old May 18, 2020 | 12:41 PM
GigG's Avatar
GigG
If your block cracked it isn't like you are going to have an option not to "start opening the engine".
Old May 18, 2020 | 12:45 PM
Pb82 Ronin's Avatar
Pb82 Ronin
What the hell could you hit at 100+ that wouldn't take the whole car out? If it spilled oil...it would get all over the rear tires and control is likely lost soon after. This is why dudes pull over on the drag strip when they break something. (And so they don't spread fluid all the way down the track adding clean-up time and dangerous conditions for other racers.)
Old May 18, 2020 | 12:47 PM
ChiefBoats's Avatar
ChiefBoats
T2T SUPPORTER
Veteran: Coast Guard
From: NNCC No Name Car Crew; Owned 1 C2, 2 C3's, 1 C4, 3 C5's, 1 C6, 2 C7's; Now '86, '03; S. DE
2023 C3 of the Year Wnner - Unmodified
St. Jude Donor '21-'22-'23-'24-'25-'26
Once you start tearing it down, you'll probably find your answer.
Old May 18, 2020 | 01:51 PM
Vet Interested
Old May 18, 2020 | 02:07 PM
HBsurfer's Avatar
HBsurfer
In your original post, you state "there is a hole in the block" followed by engine "has a good oil pressure, it works normally" WTF???
You should get your story straight before you waste everybody's time here.
Old May 18, 2020 | 08:00 PM
NYC6's Avatar
NYC6
You guys might want to cut him a little slack. I think this is a language barrier issue. Seems English isn’t his mother tongue and I looked at his info and I believe he’s from Poland.
Old May 18, 2020 | 09:52 PM
1Willy1's Avatar
1Willy1
yes I was also confused by the "good oil pressure" and "leaking oil everywhere"
Old May 18, 2020 | 10:38 PM
4271sc's Avatar
4271sc
Default cracked block
no gosciu, tos se narobil
opowiadaj...
Old May 19, 2020 | 08:15 AM
irok's Avatar
irok
It looks like the top of one of the 8 boss's cast in the valley of the engine has been broken off but they would be aluminium
To Broken block. What is this?
