Does anyone know, or have leads to an existing thread, to show if its possible for a toggle switch to be added on Mild to Wild Controller? I don't like the wireless remotes and it doesn't connect to my Homelink like some others might. I saw the thread showing the custom DIY Controller setup and that guy had it run to a basic toggle. Thought maybe someone knew a way to splice in a switch to the M2W setup? Thank you!
Thank you guys! Yes, so I had already actually purchased the M2W and discovered some time after the more custom versions that are out there. Would there, however, be a way to add a toggle to the M2W kit?
