gm pal unit
Old Jun 16, 2020 | 04:47 PM
mxking's Avatar
mxking
Default gm pal unit
awhile back I had a GM pal unit sent to ray Kawal to get programmed
I also purchased their wiring harness. After having this installed the FM radio reception is much weaker.
Ithe radio shop rechecked all connections and found nothing wrong.
Has anyone else had any issues like this
tha vette is a 07 z06 if that matters
Old Jun 16, 2020 | 06:32 PM
Dano523's Avatar
Dano523
Pal is installed with the Xm module and not by the radio, so nothing should have effected the FM reception from it's install.
As for weaker FM, would double check to make sure that the FM antenna booster in the back hatch area is still getting it's 5volts power to power up the antenna amp.
https://www.corvetteforum.com/forums...-c6-coupe.html
