Need help reprogramming key fob.
Old Jun 17, 2020 | 11:00 AM
slopoke17's Avatar
slopoke17
Default Need help reprogramming key fob.
I'm following the instructions but after turning the key 5 times, I can't get the DIC to show any messages at all. I have one good fob and tried to test the glove box slot and still nothing.
Old Jun 17, 2020 | 11:16 AM
Vette_DD's Avatar
Vette_DD
Are you saying that you have 1 good programmed fob and you're trying to program a new fob? Otherwise, there's no reason to reprogram the fob that you have.
Old Jun 17, 2020 | 11:38 AM
slopoke17's Avatar
slopoke17
[QUOTE=Vette_DD;1601690124]Are you saying that you have 1 good programmed fob and you're trying to program a new fob? Otherwise, there's no reason to reprogram the fob that you have.[/QUOTE
Yes, I have one good fob and a new one that I'm trying to program.
Old Jun 17, 2020 | 11:59 AM
FatsWaller's Avatar
FatsWaller
Try spraying some contact cleaner, and then WD-40 into the keyhole so that the key turns easier. You need to turn it all the way, just don't apply excessive force. You can also turn it more than 5 times - it won't hurt the procedure. The computer is just looking for any 5 successful turns within 5 seconds. And of course, make sure you are following the steps exactly.
Old Jun 17, 2020 | 12:40 PM
Dutch08's Avatar
Dutch08
^^^^^^^THIS I had a very difficult time getting this work. I was about to give up and then I got the "feel" of it. After that it was easy. Keep trying.
Old Jun 17, 2020 | 02:31 PM
bbjohn's Avatar
bbjohn
^^^^^^^^^^^^^^THIS Took me a few tries too.
Old Jun 17, 2020 | 11:48 PM
slopoke17's Avatar
slopoke17
Tried it again after dinner, no luck at all. I checked the battery to make sure it was good and it was fully charged. I can see how you can get frustrated.
Old Jun 18, 2020 | 12:01 AM
Vette_DD's Avatar
Vette_DD
If you get desperate enough, a GM dealer will program it for you, but that's really expensive.
Old Jun 18, 2020 | 12:07 AM
slopoke17's Avatar
slopoke17
Almost at that point right now but my stubbornness is still winning, for now. Will try again tomorrow, maybe being outside will help?
Old Jun 18, 2020 | 01:01 AM
owc6's Avatar
owc6
Do you have a Canadian or European Corvette? If so, fobs can't be programmed at home without the magic tool.
Old Jun 18, 2020 | 06:21 AM
slopoke17's Avatar
slopoke17
Previous owner from Oklahoma.
Old Jun 18, 2020 | 06:40 AM
bbjohn's Avatar
bbjohn
Locksmiths have the programming equipment (at least the one I went to). I bought a new fob and he cut the emergency key then asked if I needed the fob programmed. He was surprised that I could do it myself.
Don't know if it would be any cheaper than the dealer though. (I didn't ask)
Old Jun 18, 2020 | 07:17 AM
Dano523's Avatar
Dano523
Double check to make sure that the rear hatch lock wiring connector is still connected.
Hence the what is going on, is there is a electrical switch in the lock assembly, and Keying the cycling is closing the connection to send that signal to the BCM. So could be that the connector may need to be cleaned, could be disconnected, or switch just gummed up and not closing on full key turn instead.
Also to point out, you can't use the key to program in a export model. Also, using the Key will take 30 min wait time once you get the car into relearn mode, while tech 2 take about 3 mins, and you can erase and program a new fob into any RCDLR straight shot instead. If nothing else, its a good reason to buy a Nano for $109, so you do have a tech II on hand for wrenching on the car as well.
Old Jun 18, 2020 | 09:53 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
I had the same issue with mine. Turned the key fast, turned the key slow, WD-40 in the rear key slot, nothing. This went on over a week.
I ended up finding a good Samaritan local with a Tech II.
Good Luck with yours!
Old Jun 18, 2020 | 04:14 PM
slopoke17's Avatar
slopoke17
Tried again, still no luck. I don't know of any local good Samaritans so I think its off to the stealership. Key fob is useless as it is.
Old Jun 18, 2020 | 04:20 PM
Vette_DD's Avatar
Vette_DD
Be sure they tell you what fob number it's being programmed as.
Old Jun 18, 2020 | 05:56 PM
bobeyoung's Avatar
bobeyoung
It was suggested to me to make sure my cell phone was nowhere near the car before starting this process. I put it in the house and things worked as planned.
To Need help reprogramming key fob.
Old Jun 18, 2020 | 07:43 PM
Jeff T.'s Avatar
Jeff T.
I posted on here, help needed and found someone.
Good Luck!!
Old Jun 22, 2020 | 01:46 PM
slopoke17's Avatar
slopoke17
Well I took it to the dealer and they couldn't program it either so I'm not losing it after all! Anyway someone mentioned the rear hatch lock may not be connected (see post 13). Can someone direct me on how to check that or at least get access to it so I can make sure its connected properly. The rear hatch does open when I turn the key if that helps. Any help would be appreciated.
Thanks.
Old Jun 22, 2020 | 02:11 PM
Vette_DD's Avatar
Vette_DD
Thanks.
**** poor dealer. Try another dealer.
